Author Topic: NCDC 2015 and CID from Astra  (Read 5059 times)
Serjiouz
  • Uzbekistan, Tashkent
    • Opel Omega-B, 2000, 3.0L,
« on: 27 April 2015, 05:24:09 »
Hello Friends! I apologize in advance if similar issues have already been discussed and they have a solution. In this case, please suggest options or links.
 My problem is that before, even without knowing all the details, I was bought HU NCDC 2015 Siemenc, taken from Omega-B is not unparied from native display, security code is unknown. Later, separately purchased CID, taken from Astra-G, as well unparied and with unknown code.
 How i  read here in the same topic someone already had a problem with the display of Asters. Image shows in inverted form. Question about it: if i'l write down firmware from CID Omega, the picture will be normal or a marriage disleya? And if it possible find the firmware for the CID Omega in delivery status? Flash 93C56 already sealed-off, dump read.
 It is necessary then to associate it with my NCDC 2015. As You have already realized, we can find the code from him, from his native CDC.  2464  flash just removed, dump read. You can calculate  a security code forom this dump?
 Bring huge apologize for my English.
Unfortunately, here we do not have  the official dealer of Opel. So you have to decide everything on their own.
 I will be very grateful for any help and advice.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: NCDC 2015 and CID from Astra
« Reply #1 on: 27 April 2015, 14:05:56 »
Something else to bare in mind, is on the Computer Information within the NCDC, the Omega and Astra dont use the same Canbus signaling for this.
Serjiouz
« Reply #2 on: 27 April 2015, 15:17:02 »
Let me disagree. Omega and Astra-G  use the local Cun-bus for communication radio and display. Head units have the same platform. My set from different cars works well for 10 seconds, then lights "display safe". In this case, the radio displays the readings.  Only  Astra's display turns the image. So I want to fill in Astra's flash "delivery mode" dump from Omega, check both turn over a picture or not.
« Reply #3 on: 27 April 2015, 15:31:12 »
Omega is not canbus  :y
« Reply #4 on: 27 April 2015, 15:35:54 »
CCRT and NCDCxx plus their relevant displays and CD changers are canbus
« Reply #5 on: 27 April 2015, 16:00:31 »
CID just needs to be put in "Delivery Mode" in that case, I recall there was a method for it. But it had a less than 50% chance of success, as I think TheBoy bricked a couple of displays trying.
Also, I still think the canbus does not work in the Omega, I recall many issues of people trying to get Vectra/Zafria CID's to work, but without success, due to lack of canbus?
zirk
  • Epping Forest
« Reply #6 on: 27 April 2015, 16:08:04 »
Omega uses a form of Canbus but its not the same, to the best of my knowledge. No idea about CID Inversion, maybe a different configuration, or a different CID Module all together.
« Last Edit: 27 April 2015, 16:12:41 by zirk »
Serjiouz
« Reply #7 on: 27 April 2015, 17:46:44 »
  Indeed, there is no cun-bus in Omega, only local, for the transmission of information from the head unit to the display, as well to control the on-board computer via the head unit and the buttons on the steering wheel.
  I understand that a great chance to kill the display, but no other way. On the whole our country no more than thirty Omega cars, of which no one with a color display. Wanted to be first.
  It was very hard to find and even buy such items.  And really want to continue to fight with display and radio. With high hopes for success and forum's help . Not accustomed to retreat.
