Author Topic: MID what can you do?  (Read 4848 times)
SAMKAPPA
  • Italy Bari
    • Opel Omega b estate 2.5TD
« on: 01 May 2015, 21:30:08 »
I spent several hours searching the forum, but I did not find answers, and here I am.
Are holding an Opel Omega Estate 2.5 TD 1996. Unfortunately my MID is losing more and more pixels and has become difficult to read the information, and I want to try to improve the situation. In this case you can recommend what to do.
Thanks
Re: MID what can you do?
« Reply #1 on: 01 May 2015, 22:26:50 »
Repair it as per the guide...::)
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #2 on: 02 May 2015, 16:37:06 »
Buy a newer model mid. The one with four lightbulbs and a single grey connector. Much more reliable. You will need the connector for it as well. And you'll have to rewire the connections in the car. And finally a tech 2 session but you will end up with a mid that actually works:)
SAMKAPPA
  • Italy Bari
« Reply #3 on: 02 May 2015, 21:56:00 »
How are the results you get? It 'easy work?
SAMKAPPA
  • Italy Bari
« Reply #4 on: 02 May 2015, 22:01:35 »
I try to look for the type used with MID CONNECTOR gray, even if it seems difficult to make the setting with the tech2 for me !!
MonzaGSE
  • Norway
    • 95 Opel Omega mv6
« Reply #5 on: 05 May 2015, 16:28:27 »
Just remember early omegas (94&95) have different fuel gage ranges. Since you got a 96 you should be ok. Way to check is to look at the speedometer. Old type is divided in to 5 km/h intervalls. New type is 10 km/h intervalls. Same with rev counter old type got a line each 250 rpm, new each 500 rpm. So you SHOULD have the new type and its just a matter of rewiring. If like me (95 omega) you also need to change the fuel sender unit and the speedometer. (At least the backplate) this is to Get the range measurement corect.
SAMKAPPA
  • Italy Bari
« Reply #6 on: 10 May 2015, 22:46:48 »
If I had to find a replacement I wanted to know some more information in order to identify the parts it does for me.
I have a diesel version can use a MID that comes from a donor vehicle that is gasoline?
The language of the information of MID can change it if I find a MID in another country?
« Reply #7 on: 10 May 2015, 23:10:49 »
Asking the same question twice in two different sections won't help you get cohesive answers ;)
lesv6
    • V6 Elite
« Reply #8 on: 10 May 2015, 23:52:16 »
thats a helpful answer to a newby posting in a language not native to him
« Reply #9 on: 11 May 2015, 08:27:19 »
Actually it was...
If you had seen his duplicate question also asked yesterday, to which I had constructfully replied...
http://www.omegaowners.com/forum/index.php?topic=130340.0
It avoids confusion if each item is only posted once in the appropriate section rather than all over the place ;)
SAMKAPPA
  • Italy Bari
« Reply #10 on: 11 May 2015, 20:49:15 »
Thanks  Taxi  AL  your information is very important to me.
I beg your pardon if I used the wrong forum ..... staro more careful next time!
And above all, a big hello from Italy.
« Reply #11 on: 11 May 2015, 22:06:03 »
 ;) don't mind me...
You're most welcome :y
