Author Topic: Vac box near pollen filter: anyone got a pic?  (Read 2653 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 03 May 2015, 17:45:10 »
Had a quick look for this as I just want to check its in working order. I can follow the lines coming in to it but even with pollen filter out it seems to be a lot further back than I can get to.
To be fair I did only have a two minute check whilst under the influence lol but any info on how to get to it would be, well... Immense  :y
RIP Paul Lovejoy
flyer 0712
Re: Vac box near pollen filter: anyone got a pic?
« Reply #1 on: 03 May 2015, 22:29:08 »
Yep it is there...need very small hands to make sure of pipe connections,,but normaly ok... :y
Webby the Bear
  • Northampton
« Reply #2 on: 04 May 2015, 11:45:03 »
Yeah I thought that may be the case. I'll have another go at getting my big bear paw in there  ::) :y
Approx how far back is the box? I presume it's bolted to the bulkheads?
RIP Paul Lovejoy
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #3 on: 04 May 2015, 11:46:44 »
May get a pic today at the Wycombe meet as there's scuttle off work going on.
Webby the Bear
  • Northampton
« Reply #4 on: 04 May 2015, 12:20:03 »
Legend Chris thanks very much  :y
RIP Paul Lovejoy
chrisgixer
  • Woking ham
  • Banned
« Reply #5 on: 04 May 2015, 18:23:50 »
Sorry webby. Missed the scuttle work. :(
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #6 on: 04 May 2015, 18:30:14 »
My fault, I did remember as well but thought it was the position that was required. If you remove the short end of the scuttle it is clearly visible fixed behind the pollen filter plastics.  :y
Have a look at this link. 7th photo down clearly shows the vac box fitted to the back of the pollen filter housing.  :y
http://www.omegaowners.com/forum/index.php?topic=90650.msg1155601#msg1155601
« Last Edit: 04 May 2015, 18:46:09 by YZ250 »
YZ250
« Reply #7 on: 04 May 2015, 18:47:13 »
There's an echo in here, I ran out of edit time.  ;D Right, I'll try again.  :y
You won't see it by just lifting the flap.
Have a look at this link. 7th and 17th photo down clearly shows the vac box fitted to the back of the pollen filter housing.  :y
« Last Edit: 04 May 2015, 18:55:06 by YZ250 »
Webby the Bear
  • Northampton
« Reply #8 on: 04 May 2015, 18:58:14 »
legends cheers boys, ill get rid of the short scuttle cover  :y
hope you had a good time at the meet  :y
RIP Paul Lovejoy
