Hardest timing belts and why
Started by Webby the Bear, 04 May 2015, 19:24:25
For Audi read any VW group car with a longitudinally mounted engine...
Later V diesels are chain driven, again at the flywheel end ::)
Webby the Bear
I too have seen images of Audis with v engines (I thijk) where the timing gu bins is at the rear as Mark says near the bulk head.
Firstly, why?  :o
Secondly are they also engine out jobs or can the engine drop down enough? How the hell does it fit to the transmission I.e. Where's the flywheel or torque converter positioned  :-\
RIP Paul Lovejoy
BazaJT
Last time I changed a timing belt-and the only cars I've ever done them on-was on the Mk3 pinto engine Cortina!
Quote from: Webby the Bear on 05 May 2015, 19:25:04
Firstly, why?  :o
Firstly because they're retarded, and secondly you need to split the box... ::)
They are at least chain driven...
Webby the Bear
ah yes rear chain is now ringing bells.  :y
are they all like that? is it just the big uns etc?
RIP Paul Lovejoy
Quote from: Webby the Bear on 06 May 2015, 17:39:24
Re read reply 15... there's a good bear ::)
Webby the Bear
lol soz al. got ya got ya  :y
jusdt been watching vids on audi a4's.... pretty straight forward for the 2.0 tdi
https://www.youtube.com/watch?v=oGwDYXFPKK4
RIP Paul Lovejoy
Webby the Bear
Al, interesting how in that video he had to loosen the actual sprocket to be able to get his timing pin in.
he then states that to be set up perfectly those bolts should be bang in the middle of the small channel they live in.....yet his ends up slightly off. how could he have got that bang on> any ideas?
RIP Paul Lovejoy
Webby the Bear
ignore that, ive answered my own question..... if he'd have started at the crak pulley which is locked in place he'd have been able to feed the belt up and manipulate the cam sprocket where they were centred and withthebelt nailed in place.
I think  :y
RIP Paul Lovejoy
Omegatoy
vw t4 2.5tdi, 2 belts one at either end and 3 tensioners,one of which you use to fine tune the fuel timing loads of fun to do not! :y
Webby the Bear
that sounds awful. head mech. is going to give me some more so i can just do as many as poss  :y
question....
with a DOHC....
I thought if you had crank at tdc and locked, and cams locked correctly, youd then tension it correctly ad job done....but oh no  ::) ;D
if i do this the tension side will be, well err, tensioned lol but not the 'drive' side (or the other side). head mech tried to explain how (generally speaking so dont anyone go all keyboard warrior-ish please!) you can loosen the sprockets and dial it in (like in the vid i posted) but ive got to be honest its gone over my head slightly. anyone care to elaborate?
for work though ill just keep beavering away and hopefully the understanding will come :)
RIP Paul Lovejoy
