Author Topic: Coil packs ?  (Read 4633 times)
EMD
  • Noofhampton
    • 95t
Coil packs ?
« on: 05 May 2015, 13:41:06 »
Genuine or pattern "this is the question"  ::) And are the all the same connection for the fl ?
Anyone used a pattern coil pack thats been trouble free ?
Omegatitis
Re: Coil packs ?
« Reply #1 on: 05 May 2015, 13:46:24 »
Buy genuine Bosch and you'll have no issues :y
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: Coil packs ?
« Reply #2 on: 05 May 2015, 13:49:12 »
Bosch as said. Not dealer. Should be about £30 cheaper from a factor. Phone around.
Bosch are or supplier.
EMD
  • Noofhampton
    • 95t
Re: Coil packs ?
« Reply #3 on: 05 May 2015, 13:49:50 »
I took the Offside coil pack out yesterday and noticed a slight rust colour around the top edge , is that normal seeing as its so dry in the wells  :-\ I sprayed them with some wd , thought it mite help protect them .
Omegatitis
chrisgixer
  • Woking ham
  • Banned
Re: Coil packs ?
« Reply #4 on: 05 May 2015, 13:53:50 »
They do tend to rust. That is the failure mode, as the rust gets excessive, swells up and splits the plastic. Then it's own hill from there.
I wouldn't be applying anything else to them though.
EMD
  • Noofhampton
    • 95t
Re: Coil packs ?
« Reply #5 on: 05 May 2015, 13:58:15 »
Will keep an eye on them . They dont like oil on them either , damn fussy i say  ;D
Omegatitis
Diamond Black Geezer
    • & a silly coupe coming...
Re: Coil packs ?
« Reply #6 on: 05 May 2015, 14:11:23 »
Currently running on a pattern coil pack of unknown make. Mint cosmetic condition, no idea of make, it came off a breaker, and was a case of 'well let's see if this works, but I'll be buying a Bosch one most likely' - car runs fine, so we'll see how long it lasts.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Coil packs ?
« Reply #7 on: 05 May 2015, 14:13:22 »
Found these to be the cheapest for Bosch  :y
http://www.vauxhallworldparts.com/
EMD
  • Noofhampton
    • 95t
Re: Coil packs ?
« Reply #8 on: 05 May 2015, 17:58:42 »
Cant find them  :-\
Omegatitis
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
EMD
  • Noofhampton
    • 95t
Re: Coil packs ?
« Reply #10 on: 05 May 2015, 19:14:34 »
Omegatitis
chrisgixer
  • Woking ham
  • Banned
Re: Coil packs ?
« Reply #11 on: 06 May 2015, 00:48:56 »
Best price I've seen, personally. :y
Steve B
  • Leicestershire
Re: Coil packs ?
« Reply #12 on: 06 May 2015, 00:56:48 »
But why are they different prices... There the same thing apart from the bolts dont line up and the end plugs dont fit each other.
unless you force them and forget the bolts .. then they are good to diagnose the other side with 300 codes  :y
chrisgixer
  • Woking ham
  • Banned
Re: Coil packs ?
« Reply #13 on: 06 May 2015, 00:59:53 »
Think of it as one being even cheaper than the other :y
Re: Coil packs ?
« Reply #14 on: 06 May 2015, 01:01:17 »
 ;D Thinking sensibly, the 135 side will be more expensive as they probably sell less of them :-\
