Author Topic: 2.6 Auto estate 2002 question about traction control  (Read 2602 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Should all 2.6 Auto Omega estates 2002 have traction control as standard?
Does it also have stability control as well?
Thanks
steve6367
Re: 2.6 Auto estate 2002 question about traction control
« Reply #1 on: 05 May 2015, 21:19:30 »
Traction control yes, I don't that any Omega has ESP does it?
« Reply #2 on: 05 May 2015, 21:22:02 »
Traction control yes, stability control no, Euroland option :y
steve6367
« Reply #3 on: 05 May 2015, 22:48:05 »
Does that mean VX think we are better drivers in the UK?!
Andy A
  • Bristol UK
« Reply #4 on: 05 May 2015, 23:27:43 »
The reason I asked is because the 2.6 I'm thinking of buying doesn't have an on/off button for the traction control.
Is it permanently on or should there be an on/off button and where would it be located?
Is it possible that the original owner opted not to have it fitted?
Thanks
« Reply #5 on: 05 May 2015, 23:31:09 »
It's the third switch down on the right of the radio, and was not an option item, so fitted to all facelift v6s :y
4x4
« Reply #6 on: 05 May 2015, 23:38:44 »
When the tc symbol lights up on dash it means its off and can smoke the rear wheels  ;D
deviator
  • Chesterfield
« Reply #7 on: 06 May 2015, 07:44:31 »
Or try driving it with Triangles on the back, you don't need to turn TC off.
(They will be replaced)
