Pages: 1 [2] 3  All   Go Down
Author Topic: Twitchy rear end on my 2.2 Saloon- one side worse than the other  (Read 10578 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Also we have to remember, that a select few regard their daily commute,and every day driving experience as a qualifying lap, that has to be bettered every day.
Hoof'land storeman.
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Autogrip tyres have no grip whatsoever, I've had some bad experiences of nearly bring killed in the wet, they should be sued under the trades description act ;D
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
When I picked up my current mota, which is FWD, it has those Autogrip 'things' wrapping the rear wheels, and in slightly damp conditions, the rear of the car wanted to overtake the front.  :(
They were utter 'pish' as we say up here!  :-[
Ditch the Autogrips, before they ditch you!  :y
Got them on my estate,they grip fine in all weathers, try driving to the conditions,and not like Russel mikola,McRae,
There really is something in the water up in Northants isn't there! ;D
Thing is that's the trouble with the Autoshits. They are so appalling that no conditions exist that suit them. Other than burning in a skip of course. Does Bg drive in a burning skip I wonder ? ;D
Ordinarily most cheap tyres work to a certain level in the dry, then get caught out when it rains as there is shuch a vast difference in wet and dry performance people don't expect the grip to tail off so badly when it rains.
 But with the Autoshits they don't work in the dry either. Unless tip toeing round everything that smells like a corner of course, and on the brakes....and on acceleration actually.
In fact what conditions would these be Bg?
Absolutely THE worst tire on the market.
Since when did Huntingdon move to Northants  ;D ;D ;D ;D ;D
Clearly drinking Northants water. And no mistake! ::)
chrisgixer
  • Woking ham
  • Banned
...but what's Huntingdon got to do with it? ;D
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Leaky shock could be oiling a rear tyre, unlikely I grant you. More likely reason for slipping one is only is weight of the driver, presuming he is the only person in the car.
 I used to be keen on the sport of autotests - racing round pylons in a private car park. The party tricks were handbrake turns and 'flip turns'  In a flip turn the car is driven at speed backwards, the driver applies full right lock, applies foot brake hard, declutches, engages first gear, centres steering, engages clutch, applies power, and proceeds forwards. Sounds complicated but with practice is easy. I mention it because it is vital it is performed right hand down. That way car is stable because the driver's weight keeps that side on the ground. Done left hand down the car will almost certainly turn over. I have witnessed it several times.
Engage brain (or in your case the brain cell ;D ;D) before opening gob.  You have a pop at biggriffin and comment re water in Northants - yet if you looked BG lives in Huntingdon - hence my post
chrisgixer
  • Woking ham
  • Banned
Ayup. Charmer's on. ;D
What's where he lives got to do with it? Or can he only drink water at home according to dbug? ;D
Also, if not using those death trap Autogrips one might find the driving conditions will change very much for the better. ::) ;D
biggriffin
I do find that auto-grips come in different guises, and the ones I have fitted suit my driving style, I don't require a skate-board set-up on my barge, I can still go round corners at the same speeds as I did before, even when its raining the special water. 8)
 also welcome back Mr dbug :)
Hoof'land storeman.
Mr Gav
  • Leeds
What water would that be then? Dry water  ;D
biggriffin
We have very magical water around hoof'er land,  :)
Hoof'land storeman.
A secret blend of DDT and red diesel iirc and liberally applied to most of the east midland area as an aerosol... :-X
biggriffin
Our special water comes from
Grafham water, which is owned by
www.anglian water.co.uk
Hoof'land storeman.
biggriffin
Whoops I got it wrong, and I will admit to it.
 I have autoguards on my barge.not autogrips.
Hoof'land storeman.
chrisgixer
  • Woking ham
  • Banned
News flash. Dry water affects memory. ;D
Thought something wasn't right. A claim Autogripshits work well. Nooooo no WAAYYYY! ;D
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
Drive to the conditions?? 10-15 mph around a corner with barely a touch on the throttle?? Cant be more careful unless I stopped on the roundabout- they are horrendous!
Pages: 1 [2] 3  All   Go Up
