Author Topic: Older Vx suspension (Chevette etc)  (Read 974 times)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« on: 06 July 2008, 21:21:40 »
One for the Vauxhall die-hards here...
My playthings (Reliant Scimitar SS1) use Chevette-based  front suspension - the old double wishbone type - with an alternative shocker mount welded on (inboard horizontal).  Were there two "sizes" used on the Chevette?  I suspect that there was a slight difference between that and the Manta/Cav Mk1 setup in terms of balljoint size, but are the interchangeable to any degree?
I think they changed the wheel bearing size after the first year or so - true?  Were there any other changes during the production run?
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Re: Older Vx suspension (Chevette etc)
« Reply #1 on: 06 July 2008, 21:35:40 »
Dont know for sure, bet man father would.....
I do know that on the rally cars you used to weld a front suspension setup to the rear.....and fit the 2.3!
Olympia5776
  • Ireland
« Reply #2 on: 06 July 2008, 22:47:11 »
[/highlight]
Phil, The chevette wheel bearing was the same as the Manta A series,I had several.
I'm not quite sure what it is you're looking for is it the wishbones or balljoints?
Either register on http://www.vxopel.com/
or let me know and we'll get an answer for you.
Don
