Senator back fire
Started by hoofing it, 08 May 2015, 22:01:56
Kieran
Quote from: Andy B on 09 May 2015, 19:45:50
Quote from: chuftsmv6 on 09 May 2015, 19:32:12
Hi there i love the senator I havnt seen one for years  ....
Me neither, though my daughter sent me a picture of a civvy L reg Senator she was sat behind at the traffic lights a few weeks ago
Was the reg L464 by any chance. It may be my one.
terry paget
You say timing is spot on. I just mention that on my last 24 valve performance was getting worse over months, I finally traced the fault to the crank sensor reluctor ring having moved on the crankshaft. On the Senator the reluctor ring is on the end of the crankshaft, sharing a Woodruff key with the cam chain sprocket and I think the oil pump gear. Anyway. what happened was that someone had changed the cam chain, damaged the Woodruff key so that the reluctor ring, on the outer ring could move, and was doing so. Sadly, I failed to remove the nut, despite using heat and a large impact wrench, so scrapped the car.
You car is a 12 valve, so the duplex chain presumably has not been touched.
Omegatoy
had to sort a carlton 12v few years ago, sounded like a bag of spanners, backfiring up the inlet,ran but only just,anyway after a fairly involved few hours,found the timing chain guide had broken,allowing timing to fluctuate,this allowed the hydraulic tensioner to expand to far as it tried to compensate,so oil pressure was low,polished the crank new big ends and mains i could get to :-X new tensioner, broken part was in the sump,it had just snapped, mileage was 86k?
Quote from: Kieran on 11 May 2015, 15:31:40
Sorry. Only just seen this reply.
No sorry. This was L910 XPF There can't be too many left on the road, especially as a daily runner.
