Pages: [1] 2 3  All   Go Down
Author Topic: NCDC 2013/15  (Read 11630 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
NCDC 2013/15
« on: 08 May 2015, 22:34:50 »
Can a Bose NCDC 2013/15 be set to non Bose with Tech2 ? :-\
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: NCDC 2013/15
« Reply #1 on: 08 May 2015, 22:42:29 »
I'd bet on yes. But not sure.
Let's see what they say. :)
It lives then?
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: NCDC 2013/15
« Reply #2 on: 08 May 2015, 22:51:42 »
No its still in bit on the table (wife not happy) put new parts in only to find I have now got a spring and I don't know were I got it from (it's from the Nav part) its the thick one (and not me) about 12mm ish long, sorry its at home and I'm at work  :-\
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: NCDC 2013/15
« Reply #3 on: 09 May 2015, 02:29:50 »
I must be getting old, as I asked this question in Jan, if I'd asked it 20 years ago I would have remembered. ;D ;D
powerslinky
Re: NCDC 2013/15
« Reply #4 on: 09 May 2015, 07:12:42 »
Umm!  interesting question that :-\
Never seen  a 2013/15 running on a non Bose system though.
Along with Mr.Gixer , I would bet yes  . . . but lets see what TB or DaveDND say  :-\ :-\
I will be watching this thread with interest as I have a spare 2013 with paired screen & a car without Bose ::) ::)
« Last Edit: 09 May 2015, 07:24:53 by Essex Big Al »
powerslinky
Re: NCDC 2013/15
« Reply #5 on: 09 May 2015, 07:46:28 »
Just searched through your January posts  . . .
Seems it's a yes ( but you already know that  . . not to worry John ,it's an age thing , I have the same problem ;D ;D ;D )
Re: NCDC 2013/15
« Reply #6 on: 09 May 2015, 09:48:01 »
It's a yes :y the NCDC201x were available as a factory option from CD up, Bose was Elite only iirc...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC 2013/15
« Reply #7 on: 11 May 2015, 10:20:49 »
Like most of the range, some can and some cannot.
If it has BOSE written anywhere on the fascia, then its unlikely, but if it only says BOSE on the screen when powered up, then there is a 75% chance that it can be reprogrammed with a Tech2 session.
Radio & Decoding Technician
www.dndservices.co.uk
    • 530D M Sport, 330i Coupe
Re: NCDC 2013/15
« Reply #8 on: 11 May 2015, 12:22:14 »
Think that's valid for CCR2006 only, all NCDC2013/15 models can have the Bose option tweaked by a Tech II and none have Bose Logo on the bezel. The Bose logo on the screen can be tweaked by a Tech II as well regardless of Bose actually being installed.
Re: NCDC 2013/15
« Reply #9 on: 11 May 2015, 18:56:32 »
All NCDC and NCDR units can be set to both Bose and non-Bose
All CCR2006 can be set to non Bose, but only a very few can be set to Bose.
HTH
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: NCDC 2013/15
« Reply #10 on: 22 May 2015, 16:53:33 »
So put the new laser and CDC unit in and found out were the other spring went, just put it all back in the MV6, CDC works fine but Sat-Nav keeps ejecting disc with a message of (please put disc in with printed side up) which it was and that's with a new laser :-\ any clues please. :y
Next is to have the clocks out to see if I have the extra lead fitted for CID display  :D ::) if so it will be in with the known good NCDC2013 unit :y and if not I have two leads here so will need to fit one.
Re: NCDC 2013/15
« Reply #11 on: 25 May 2015, 10:16:49 »
Assuming this is a new laser, have you cut the soldered bridge on the ribbon cable off?
Re: NCDC 2013/15
« Reply #12 on: 25 May 2015, 13:47:40 »
Even the brand new lasers don't like CDRs.  Are you using a genuine disk?
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: NCDC 2013/15
« Reply #13 on: 25 May 2015, 13:49:31 »
Yes two of them so far :'(
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: NCDC 2013/15
« Reply #14 on: 25 May 2015, 13:50:20 »
should I :-\
Pages: [1] 2 3  All   Go Up
