Author Topic: Strange oil drips  (Read 4141 times)
Malcolm_D
  • York
  • It shines!
Strange oil drips
« on: 09 May 2015, 22:28:31 »
02 2.6 Elite. Having given the engine and the plastic undercover a clean recently I am puzzled to see a dribble and a few spots of what appears to be a clean light grade oil on the top lip of the sump edge and the plastic undercover just below the aircon compressor. I have cleaned it off once but it has reappeared.
I don't think that it is engine oil as it is too clean (even though I have just done an oil change) and it doesn't feel thick enough.
Any ideas?
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Strange oil drips
« Reply #1 on: 10 May 2015, 08:17:09 »
Are you sure it's oil?It sounds very much like you may have an aircon leak.No doubt someone more knowing than I will be along shortly to shoot me down in flames about that.
Malcolm_D
  • York
  • It shines!
« Reply #2 on: 10 May 2015, 12:46:43 »
That thought had crossed my mind as well. The aircon is nice and cold so it appears to be working (at the moment!). I am trying to identify where the drips are coming from so that I can tell what the fluid is and what is leaking.
4x4
« Reply #3 on: 10 May 2015, 14:38:36 »
Power steering leak,cooler,pump,pipes   :y
BazaJT
« Reply #4 on: 10 May 2015, 19:55:03 »
Colour may give a clue ATF/power steering fluid should be a red colour while I understand that aircon leaks show up green?
Malcolm_D
  • York
  • It shines!
« Reply #5 on: 10 May 2015, 22:19:51 »
This is neither, it is clear.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #6 on: 10 May 2015, 22:25:42 »
Spillage from a top up? Leaking filler neck seal?
chrisgixer
  • Woking ham
  • Banned
« Reply #7 on: 10 May 2015, 22:59:06 »
Leaking ac oil compressor? (Assuming no die)
Malcolm_D
  • York
  • It shines!
« Reply #8 on: 10 May 2015, 23:24:38 »
Had the aircon serviced and regassed after replacing a leaking pipe two years ago, dye was put in according to the sticker in the engine bay so it should be green.
Oil and filter changed recently, no spillage at all (a bit OCD!), wondered if it could be a leak from the base of the dipstick tube, don't think it is from where the filler neck joins the cam cover although I will certainly check. Just felt too thin to be engine oil but I could be wrong.
Will continue to investigate.  :-\
Malcolm_D
  • York
  • It shines!
« Reply #9 on: 11 May 2015, 21:06:28 »
Have investigated further I now believe that the oil is ATF from the steering pump as it appears to have a slight red tinge to it. All I need to do now is to find out which part is leaking!  :(
Can the power steering pump be removed without having to first remove the aircon compressor?
4x4
« Reply #10 on: 11 May 2015, 21:11:25 »
Tighten up the jubilee clips on the feed pipe from reservoir to pump.
Malcolm_D
  • York
  • It shines!
« Reply #11 on: 11 May 2015, 21:20:27 »
Sounds like a sensible first step.
Have found a guide on the forum, written by johnnycboy, for removing pump if necessary, without taking off the aircon compressor which is what the Haynes manual tells you is needed!
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #12 on: 11 May 2015, 21:38:57 »
Wipe the pipes and rubber hoses down while you're at it; the hoses might be perished and leaking. Which an easy and cheap fix, using a few quids worth of hose, if a bit messy.
Malcolm_D
  • York
  • It shines!
« Reply #13 on: 11 May 2015, 22:35:53 »
Need to check more closely for perishing etc but on first inspection the jubilee clip at the bottom end of the rubber hose was not tight, could move it with my fingers! Now tightened and 'splash zone' cleaned so lets see if the problem is sorted.  :-\
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
« Reply #14 on: 11 May 2015, 22:40:50 »
breaking a 2.6 if you need the pipe  :y
