Author Topic: hesitation on throttle / gearbox response  (Read 7109 times)
pauls
  • By the sea minehead
    • Bmw x3
« on: 12 May 2015, 15:21:27 »
This is difficult to explain but sometimes when you give it bootfull it will think about it then go, other times it will change gear then change again. No thuds or code since replacing the gearbox and gearbox ecu. Perhaps mr Chrisgixer can word it better as he has experienced the fault. Also sometimes when you boot it then lift off it feels like the revs dont drop.
Probably a silly thought but what controls the throttle peddle. was just thinking perhaps engine/gearbox is being told the wrong thing so not sure what to do.
lesv6
    • V6 Elite
Re: hesitation on throttle / gearbox response
« Reply #1 on: 12 May 2015, 15:28:25 »
Your right foot controls the throttle pedal ;)
first try cleaning throttles and make sure spindles are free moving and not tight
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #2 on: 12 May 2015, 15:45:04 »
It's drive by wire ::)
chrisgixer
  • Woking ham
  • Banned
« Reply #3 on: 12 May 2015, 15:47:26 »
Any engine codes? Pedal trick?
It could just be the start of a misfire, or some other engine management hic up.
If it's a slight misfire, it could see the reduction in torque and change up, thinking you've throttled off. For example.
Did it get software update?
pauls
    • Bmw x3
« Reply #4 on: 12 May 2015, 15:55:16 »
No codes using pedal trick.
No updates all upto date.
Thinking about misfire would this be caused by old spark plugs. Couldnt see anything in the history for changing them since 2007.
lesv6
    • V6 Elite
« Reply #5 on: 12 May 2015, 17:00:18 »
I know, same as my 3.2
as i said clean throttles and spindles first, could be sticking. remove bagpipes and unbolt throttle bodies. if no improvement could be iffy tps
« Reply #6 on: 12 May 2015, 18:10:44 »
I would also ensure breathers and throttles are spotless. Then I would be looking it seeing if the trims are drifting out
chrisgixer
  • Woking ham
  • Banned
« Reply #7 on: 12 May 2015, 20:20:03 »
You know, yet post that that the drivers foot sets the throttle. It  doesn't , the Tps does. ::)
chrisgixer
  • Woking ham
  • Banned
« Reply #8 on: 12 May 2015, 20:23:01 »
Possibly. It might be coil pacs breaking down. It could also be a number of other things. I'd be pulling the drivers coil PAC for a look see. Along with the other suggestions.
..although I drove an omega with blocked breathers for some time. It didn't behave like this does. It's a drop in power. But why...?
« Reply #9 on: 12 May 2015, 20:56:52 »
On these, shitty breathers tend to give stickiness to DBW throttles (or in extreme cases, actually knacker the gears in the servos - but I've only ever send that once myself), which was my reasoning for suggesting cleaning.
But I'm not convinced in this case, hence wanting to see trims (and/or MAF at point it fails)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #10 on: 12 May 2015, 21:00:24 »
Is it the same with the TC off ?
pauls
    • Bmw x3
« Reply #11 on: 12 May 2015, 21:10:55 »
I have cleaned the breathers, all pipes and box. I havnt tried it withe the tc off. Today I noticed the indecisive gearchange when engine was cold, I drove about half a mile to the a40 on the way down the on ramp hit the peddle and it seemed to change twice. After about 30 mins of driving around went back on the a40 pressed on to just above 80 then lifted off and for a second or two nothing happened then the revs dropped and the speed dropped.
chrisgixer
  • Woking ham
  • Banned
« Reply #12 on: 12 May 2015, 21:19:30 »
This is at wot in third iirc, or was it in second... Certainly wot, at a tad over 5k rpm. So given the road in question, more likely second.
So not near rev limiter.
Not near a gear change point.
Not during throttle movement. (Assuming no fault of course, as it should be wide open and the symptom would suggest it's trying to close if a Tps fault)
Not near a multi ram movement. (Iiuc?)
Basickly engine at full load at 5,200 odd rpm. Slight hesitation/drop in load until 5,500 and off it goes again.
I'd be looking at engine management I think? O2 or Maf or spark. ....fuel filter?
Something breaking down at full load anyway.
There is a concern the box is trying to change gear. Which is sort of feasible.  Box replaced with matching ecm from same dinar vehichle as the box. Known good.
Has the fluid level been re checked since the box change Paul..?
chrisgixer
  • Woking ham
  • Banned
« Reply #13 on: 12 May 2015, 21:22:01 »
This is a new symptom, to me anyway. I haven't experienced this. Would you say the revs dropped as if throttle off?
pauls
    • Bmw x3
« Reply #14 on: 12 May 2015, 21:29:47 »
Sorry worded it wrong revs dropped and speed dropped as there should, it just seemed to hold onto the revs a bit longer than expected when I lifted off. Hence my question could the throttle stick..
