Author Topic: abs ecu, will it fit?  (Read 6788 times)
Re: abs ecu, will it fit?
« Reply #15 on: 16 May 2015, 20:15:48 »
Should I try to replace the entire unit?
No
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #16 on: 16 May 2015, 23:39:24 »
they are both 3 channel, just wondering if there could be something wrong with the electronics inside :P
Do i need to tell the dealers the ident code from the unit the ECU came from?
« Reply #17 on: 17 May 2015, 07:19:57 »
Ah, just noticed your location, which may be confusing things for me  :-[
What is the last letter of your VIN
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #18 on: 10 June 2015, 21:44:29 »
The last of the letters is V
The car has been at Opel again, and they the "new" ECU is also not working, could it be the electronic bits inside the unit itself that has failed, meaning I have to change the entire unit?
« Reply #19 on: 15 June 2015, 18:47:29 »
Not mini facelift then, so 3 channel. Going to need a code reader on the unit - although these earlier ones are normally bombproof
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #20 on: 18 June 2015, 20:46:14 »
Opel said the new unit had a relay error (so another fault then last time)
Could this be because i didn't change the entire unit, or will i need another ECU
