Author Topic: oil leak . . rear crank seal ?  (Read 3712 times)
powerslinky
« on: 17 May 2015, 12:15:41 »
Ok guys
             3.2 has developed an oil leak . Started a week or so ago. I thought it was the oil filter housing to block seal as the leak seemed to be coming from that area & running down to the 2 bolts at the bottom of the bell housing .
Yesterday done away with the canister & cap oil filter & changed to spin on . . . but leak is still there .
Area above the oil filter is dry but oil is appearing from the bottom of  the crankshaft sensor where it fits into the block.
I have taken out both rubber bungs at the bottom of the bell housing & no oil appears there .
Oil does appear though at the very small oblong hole  (10mm x 2mm) at the bottom of the bell housing .
Could this be the rear crankshaft oil seal gone & spraying oil about making it seep from both the crankshaft sensor hole & the
small oblong hole at the bottom of the bell housing . This leak is only small  . . . leaving a small 75mm patch  on the ground overnight.
Cam covers are all ok & dry as were changed last year.
any advice greatly recieved .
Regards, Al :y
« Last Edit: 17 May 2015, 12:18:10 by Essex Big Al »
Re: oil leak . . rear crank seal ?
« Reply #1 on: 17 May 2015, 15:32:09 »
Ok guys
Regards, Al :y
Definitely rear crank seal...
In fact I would go as far as to say that is precisely why that little hole exists ;)
« Last Edit: 17 May 2015, 15:33:45 by Taxi Al »
powerslinky
« Reply #2 on: 17 May 2015, 19:08:16 »
Ok guys
Regards, Al :y
OK then . . . so AR35 & torque convertor out as one  . . . drop & pull back out of the way  . . dig out old oil seal  . .
carefully fit new one  . . . AR35 & TC back in .
Presume follow Haynes book of lies to drop gearbox , Re: starter, gearbox switch , prop etc.  ? :-\   As cannot see a defined guide on here for that :-\ :-\
Anything else I should be doing while this is out & being sorted ?
Any idea of cost of the oil seal ?   can't be too expensive . . . cough cough :-\
« Last Edit: 17 May 2015, 19:16:04 by Essex Big Al »
« Reply #3 on: 17 May 2015, 19:11:17 »
Gearbox thrust washer might be prudent :-\
powerslinky
« Reply #4 on: 17 May 2015, 19:20:12 »
I will have a look up on that one then  Al  . . . .is it  easy to do  ?
« Reply #5 on: 17 May 2015, 19:22:28 »
Never done one in all honesty... Plenty have though, so should be well documented :y
powerslinky
« Reply #6 on: 17 May 2015, 19:32:21 »
search mode needs to be  engaged then   ;D ;D
« Reply #7 on: 17 May 2015, 21:02:01 »
£30odd from Vx a few years ago
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
« Reply #8 on: 17 May 2015, 21:36:57 »
Don't forget the drive plate has to come off too.
I used to know everything. Then I got married.
Shallow Al
    • 3.0 Litre Elite.
« Reply #9 on: 17 May 2015, 21:41:18 »
Could do the auto box seal as well. Easy to do with the box out. If dry, gamble and leave it.
But I am not a lucky man :'(
Matchless
  • Nottingham
    • A white van
« Reply #10 on: 18 May 2015, 13:29:31 »
There is a trick to fitting the rear crank oil seal.
If you simply try to press and tap it in, then it will likely leak again .... dont ask how I know.
You need to find some thin rigid plastic sheet or similar (I had some brass shim available), you wrap this around the end of the crank and secure the overlap with sellotape etc. to form a tube.
Take the tube off the crank. Lube the oil seal and gently ease the tube into the oil seal from the outside, being careful not to damage the seal lip.
Now offer tube and seal up to the crank and engine and press / tap into place. The tube guides the oil seal lips over the end of the crank.
powerslinky
« Reply #11 on: 18 May 2015, 21:02:02 »
All above replies & advice  acknowledged . . .  thanks  :y
