Author Topic: Aux Belt Tensioner  (Read 3584 times)
brendan1983
  • Hampshire
    • Omega CDX Saloon
Aux Belt Tensioner
« on: 19 May 2015, 08:13:04 »
Hi All,
I have been getting a bit of an odd whirring sound from the 2.2 lately - after much worrying if it was the torque converter or something serious last night I had a proper look, took the Aux belt off and the sound went.
From turning everything pretty sure it's the tensioner that's to blame - turning it by hand feels like the bearings have gone.
My main question is though (as I cant see them easily) is this held on with any special bolts - or any special tools required for removal?
Thanks
Brendan
2003 CDX & Yamaha Thunderace
Re: Aux Belt Tensioner
« Reply #1 on: 19 May 2015, 09:37:23 »
Three bolts IIRC
« Reply #2 on: 19 May 2015, 09:40:00 »
Nothing fancy about it, but a bit fiddly iirc... certainly not the hardest of jobs :y
And as Robs pic reminds me... the tensioner needs locking in position in order to undo all three bolts... use the dowel location on the new replacement as a visual reference  :y
brendan1983
  • Hampshire
    • Omega CDX Saloon
« Reply #3 on: 19 May 2015, 09:42:57 »
Awesome - thanks guys
I don't suppose you know if they're torx bolts or regular?
(Just so I know if I'll need to get some Torx sockets before I start)
« Reply #4 on: 19 May 2015, 09:49:09 »
Torx iirc :y
« Reply #5 on: 19 May 2015, 10:36:09 »
Most cars these days mainly use Torx bolts  ;) Both Torx sockets & Torx bits will be useful to anyone working on their car .... you can get a decent set of each fairly cheaply. Just be careful of some Torx sockets if they're all 3/8" as the body of the smaller sizes can get in the way, the set from Machine Mart has 1/4" 3/8" & 1/2" drive
brendan1983
  • Hampshire
    • Omega CDX Saloon
« Reply #6 on: 19 May 2015, 11:57:24 »
Time to invest in some I think - I've never had a need for any before, I guess maybe my bikes/cars have just always been too old
« Reply #7 on: 19 May 2015, 17:50:36 »
Maybe your tensioner just needs a little grease.  ;)  :y
« Reply #8 on: 19 May 2015, 18:43:18 »
If it feels notchy, as opposed to just dry, I'd replace.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #9 on: 19 May 2015, 18:52:43 »
It is attached by 2 long E14 male torx screws. I put mine back on this morning after changing the cam belt.
There must be lots of spares on this forum. When I strip my dead 2.5 down I shall have one!
4x4
« Reply #10 on: 19 May 2015, 18:59:24 »
You could replace the bearing on its own tho  :y
« Reply #11 on: 19 May 2015, 22:36:49 »
Four pot tensioners are different in design and are mounted using three bolts :y
brendan1983
  • Hampshire
    • Omega CDX Saloon
« Reply #12 on: 20 May 2015, 08:48:02 »
I picked up a new one from ECP yesterday - fitted it last night  :y
Surprisingly it was just two 13mm bolts - the old one was very rough to turn by hand, also I hadn't realised just how noisy it had become...
Thanks for everyone's input  :)
