Author Topic: Clonking type sound coming from the rear...  (Read 4845 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« on: 19 May 2015, 15:53:55 »
It can't be the exhaust I have triple checked everything is secure, The shocks are around a year old along with the springs so can't be them all good quality parts, Everything in the boot is secure what little there is in there.
Here's a short clip which does pick up some of the sound I'm on about on rough surface roads.
http://youtu.be/czfL8rpNkwA
I'm not sure what else it could be tbh  :-\
« Last Edit: 19 May 2015, 16:05:05 by Mr.OmegaMan »
deviator
  • Chesterfield
Re: Clonking type sound coming from the rear...
« Reply #1 on: 19 May 2015, 16:18:09 »
Hmm, that is quite difficult to diagnose from afar. I presume you've been in the back of the car with the seats down whilst someone else is driving? The reason I ask is to rule out interior trim.
Top mounts
Drive shafts (IE CV Joints)
ARB Drop links
ARB Bushes
Wishbone bushes
Heat shield
Lose fuel filter
There are so many things it could be, the best way to find it is to jack the rear up and then have a pry around. With the exhaust, normally, I just stick my foot on the tail pipe and give it a good push/kick/rattle around to see if I can hear anything.
pauls
  • By the sea minehead
    • Bmw x3
« Reply #2 on: 19 May 2015, 16:21:52 »
Thats sounds like your spring has snapped
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #3 on: 19 May 2015, 16:27:25 »
Top mounts
ARB Drop links
ARB Bushes
Wishbone bushes
Heat shield
Lose fuel filter
I haven't tried/checked the highlighted as of yet  :y, But visual everything seems fine underneath. Just need to try and eliminate things  :-\
Sachs springs bought around July last year, Also passed an MOT a few days ago. Did also inspected the springs myself mind and they are intact.
deviator
  • Chesterfield
« Reply #4 on: 19 May 2015, 16:44:14 »
As the noise occurs when on suspension travel, could you stand in the boot and jump up and down? Not to replicate the fault, but to entertain your neighbours  :D
Seriously, if it makes the noise stationary, then it's got to be suspension pretty much.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 19 May 2015, 16:51:24 »
Tried something similar... ::) opened the boot lid an push up and down lightly and firmly by arms and then by sitting up and down.. Not a peep completely silent. Rear suspension is a little on the firm side possibly with bilstein shocks but don't see that causing this issue  :-\
EMD
  • Noofhampton
    • 95t
« Reply #6 on: 19 May 2015, 17:36:25 »
Ive got a similar sound but a bit lighter , i think its top mount nearside  :(
Omegatitis
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #7 on: 19 May 2015, 19:09:06 »
It's not an unbearable sound but nevertheless it's still there gnawing at your sanity  ;D
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #8 on: 19 May 2015, 19:36:29 »
I'm gonna go with......Shock mount.
Could be anything though tbh. But it is in relation to small stutter bumps, not something you can re create with a shove on the rear.
chrisgixer
  • Woking ham
  • Banned
« Reply #9 on: 19 May 2015, 19:37:14 »
Worth the pointing your camera at the top mounts in the boot?
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #10 on: 19 May 2015, 19:52:44 »
I'll have rear subframe bushes.
That's what's causing mine to clonk like a four letter word.
Omegatitis : [in remission]
« Reply #11 on: 19 May 2015, 22:34:03 »
Did you fit the light weight rubbish top mounts supplied with the shocks?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #12 on: 19 May 2015, 22:37:53 »
More than likely, Can't recall tbh. But probably yeah seen as they where new.
« Reply #13 on: 19 May 2015, 22:41:56 »
Jack the car up and wiggle the shock body where it meets the dust cover... any play and replace the topmounts using the following parts:
90447244 Cup x 4 £2.40 (washer, four required)
90250288 Rubber Bumper x 2 £3.97 (top mount upper rubber, two required)
90447245 Insulation x 2 £3.14 (top mount lower rubber, two required)
90447246 Spacer Sleeve x 2 £2.49 (fits inside top mount lower rubber, two required)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #14 on: 19 May 2015, 22:55:58 »
Thanks Al, Will give it a once over this week sometime  :y
