Pages: 1 [2] 3  All   Go Down
Author Topic: Omega 2.6 estate 2002 rear vented disc brake pad kit part number needed  (Read 10420 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Every set I got was to small, the only ones that are the correct size are from the dealer as Al has said, been down that road in Feb this year. Looked at just about every make going and they were all to small.
But if you do find the Hens teeth then please let us all know so we can buy some :y
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Did you try the Delphi LX0268?
Andy A
  • Bristol UK
I might be able to get hold of some decent used longer pins and springs - but can't vouch for the condition of the springs, that's all. May be fine, may be rotten. Were lathered in coppergrease, so fingers crossed they're ok underneath.
I did try and send you a PM but your box is full. What do you want for them posted?
Hopefully the springs will be OK as one of mine fell apart and the other was gone altogether. Although the pins are not good either.
Thanks  :y
« Last Edit: 21 May 2015, 17:27:16 by Andy A »
  • Online Online
Thanks  :y
On all the Vauxhalls & Opel I've had with similar pins to retain the pads ..... they've ALL had them ..... I've never had need to replace any of them - why would you have need to replace them? There's nothing to break!  ???
I have though, replaced the cross shaped anti-rattle spring from across the top though.
Andy A
  • Bristol UK
Thanks  :y
Andy, when I took the pins out they were badly corroded and even after rubbing them down with very coarse emery cloth they still have bad craters in then. That is why they need replacing. Unless you think that would be OK?
« Last Edit: 22 May 2015, 08:34:09 by Andy A »
Diamond Black Geezer
    • & a silly coupe coming...
I'm hoping to get to the scrappy Saturday. This depends on family, girlfriend, time, money, car and a load of other stuff that's dead easy!  :y
Andy A
  • Bristol UK
Just wondered if you managed to find enough spare time to look at the clips and pins and get them?
If not don't worry about it, I know what its like myself.
Thanks
Andy A
  • Bristol UK
Any luck with the springs and pins?
Thanks
  • Online Online
Sorry ..... I missed this question
As long as the spring barrel clip is a tight fit such that when the pin is fitted, it stays put, I wouldn't worry too much about corroded pins ...... as long as they're not almost rusted through.  ;)
Chances are that by the time the pins are that rusty, the anti rattle spring will have long since disolved and fallen out.
Better to replace, which sadly means Vauxhall...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Alternatively use 2 large split,pin, running opposite ways and lock wire thro the loops,
And before hse Muppets start, works perfectly well on most forms of race car calipers.,or make up two pins and use double lock wire, or micro R-clips, as on a lot of merc's use to have.
« Last Edit: 28 May 2015, 13:27:40 by biggriffin »
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
That's a quick, cheap, effective and easy universal solution.
We don't have those here!
The Omega Inquisition will be plumping the cushions on the comfy chair as I type this.
Andy A
  • Bristol UK
What a dam good idea. Thanks.  :y
Tricky Dicky
  • Farnborough Hampshire
    • Omega CDX 2.6 manual
I gave up with the local factors and went to V/X and got 4 pins & 2 springs on order. I work there occasionally as part-time driver and got staff discount.... still nearly £ 38 !!!
Andy A
  • Bristol UK
The cost is putting me off. Way to expensive for what it is for. I still can't believe that none of the other brands can't get the pin lengths and spring clips right for the vented rear discs.  :o
Pages: 1 [2] 3  All   Go Up
