Any way to tell?
Started by BazaJT, 20 May 2015, 19:18:17
BazaJT
Got a new torque wrench ready for when I tackle cam cover change.It's a Toolzone make,feels a little stiff to me but that could be just because it's new,or maybe it's just a crap make I don't know.Anyway is there any way to tell whether it's clicking off at the correct value?Something else on the car that's the same torque that I can try on or some other way?
Terbs
Try the ones holding the 'breather' plate on (under the Eco plate)...they are 8nm, also the four bolts facing forwards on the throttle body attached to the Plenum....sure they are 8nm too :y
Hold the square in a vice so that you can hang a weight on the handle at specific distance. Set the gauge at eg 50Nm and then hand 50kg at 1 metre ... it should 'brake' if correct
deviator
As these bolts are normally overtightened, couldn't you set it 8nm and try and undo them. If it clicks before they crack, then either you wrench is low or the bolts too tight.
EDIT
Quote from: Andy B on 20 May 2015, 20:06:59
Wouldn't the 1-2Kg the wrench weighs throw this out?
Hold the square in a vice so that you can hang a weight on the handle at specific distance. Set the gauge at eg 50Nm and then hand 5kg at 1 metre ... it should 'brake' if correct
Fixed. ;)
Quote from: Kevin Wood on 20 May 2015, 20:40:53
Fixed. ;)
Ta! ;)
It's been a while since I did Physics O level .... but I was close  :y :y
Quote from: Andy B on 20 May 2015, 20:42:25
Fixed. ;)
Ta! ;)
Had to think about it for a minute myself. ;D
Quote from: deviator on 20 May 2015, 20:27:45....
no idea, but I'd not worry over 1 or 2kg or a couple of Nm or lb/ft either way  :y
Quote from: Kevin Wood on 20 May 2015, 20:43:34.....
I'm still thinking .....  ::)
Only a factor of ten out.. I hope you're not a nurse, Andy!  :P
Webby the Bear
You're wise to check it baza. I purchased my naff low range torque wrench. And I stupidly just dived right in expecting it to click at 8nm on cam covers. Bugger didn't click at all. Not even slightly. This was mid job so I had no choice but to just snug them up. Seems to have worked out. Hope yours works ok
RIP Paul Lovejoy
Ta! ;)
weights as accurate as a fat bird on a diet! ;)
Bigron
If you have the wrench horizontal so that the weight of the lever isn't a factor, you can apply the torque with a spring balance or, preferably, one of those cheap portable digital luggage scales from Lidl/Aldi and pull on it to the required force.
Ron.
deviator
Quote from: Bigron on 20 May 2015, 23:25:26
Ron.
So simple it's genius, I feel stupid.
Diamond Black Geezer
Hey lad,
If you're in my neck of the woods feel free to compare yours with my wrenches. They're a little and largest ones halfords do. Made in England and each comes with a calibration certificate. Both used less than a dozen times.  :)
