Author Topic: 2.5 V6 Stat  (Read 3696 times)
steve6367
2.5 V6 Stat
« on: 20 May 2015, 21:22:48 »
2.5 Thermostat - VX have advised today that the seals are on back order with the factory and can't supply atm.
Are there any known good sources of thermostat and transfer pipe?
Re: 2.5 V6 Stat
« Reply #1 on: 20 May 2015, 21:32:16 »
eBay for the stat. £20. It's a genuine part :y
Re: 2.5 V6 Stat
« Reply #2 on: 20 May 2015, 21:32:41 »
That comes with seal :y
steve6367
Re: 2.5 V6 Stat
« Reply #3 on: 20 May 2015, 21:33:42 »
Thanks James, do you have a link?
A eBay search has revealed many options!
steve6367
steve6367
Re: 2.5 V6 Stat
« Reply #5 on: 21 May 2015, 08:18:26 »
Anyone help on the Stat and eBay? I think I remember one from the U.S. Being mentioned before?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: 2.5 V6 Stat
« Reply #6 on: 21 May 2015, 08:38:32 »
Re: 2.5 V6 Stat
« Reply #7 on: 21 May 2015, 11:05:20 »
http://www.carparts4less.co.uk/cp4l/c/Vauxhall_Omega_2.5_2000/p/car-parts/car-cooling-parts-and-car-heating/cooling/car-thermostat/?209880071&1&efce642d4500b3ceb1c4f09d2322575b2e501310&000325
If you are careful you should be able to split the transfer pipe from the thermostat housing. I've always managed it and I'm pretty ham fisted!  ;D
However a new transfer pipe will only be about £15 from the dealer so it might be worth getting one especially as they come with new 'O' rings.  ;)
Depends how lucky you're feeling and how quickly you need the job done!  :y
Just to add, you can usually find a discount code for CP4L so have a hunt around.  ;)
« Last Edit: 21 May 2015, 11:15:59 by Sir Tigger »
steve6367
Re: 2.5 V6 Stat
« Reply #9 on: 21 May 2015, 13:28:51 »
Thank you all - this is the one I think I had in my memory, but as its got a long delivery time I shall go for one of the others  :y
http://www.ebay.co.uk/itm/200914781107?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Steve
Re: 2.5 V6 Stat
« Reply #10 on: 21 May 2015, 15:54:11 »
Steve
Yes, Why buy one from the US....  :-\
I bought one from ebay recently and the O ring didn't fit properly so beware! The Wahler thermostat that I bought was much better!  :y
Re: 2.5 V6 Stat
« Reply #11 on: 21 May 2015, 23:26:32 »
Steve
No issues with the Ac Delco one..  Genuine stat for 2/3 the price of a vauxhall sourced one...
No prizes for guessing what I fitted to mine... Transfer pipe is best sourced from Vauxhall at £12-15 :y
EMD
  • Noofhampton
    • 95t
Re: 2.5 V6 Stat
« Reply #12 on: 22 May 2015, 09:45:55 »
Bought transfer pipe last week from stealers £17 , wonder how long these will be available as never seen a pattern alternative  :(
Omegatitis
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: 2.5 V6 Stat
« Reply #13 on: 22 May 2015, 19:33:34 »
Get a transfer pipe,before you change the thermostat.,as sods law will intervene.
Hoof'land storeman.
steve6367
Re: 2.5 V6 Stat
« Reply #14 on: 22 May 2015, 19:36:25 »
I have the transfer pipe - when I did the salon I got luck so still have it  :y
(bet I won't be lucky twice!)
