Author Topic: replacement radio/cd options  (Read 8015 times)
cjackel492
  • Sussex
    • 2001 Omega Elite 3.0
Re: replacement radio/cd options
« Reply #15 on: 25 May 2015, 00:16:02 »
If your car has Bose, be prepared to rewire the entire audio system and speakers ;)
Or just fix a 6 channel amp capable of driving 2 Ohm speakers. Fit the amp under the rear shelf where the bose amp is located as you'll have direct access to all speaker wires.
Carl,
steve6367
« Reply #16 on: 25 May 2015, 09:08:06 »
Carl,
I don't know on the Bose kit in these cars but generally Bose uses a lot of signal processing to achieve a good sound / protect the speakers - unless your amp can replicate this I suspect it will not sound good / destroy the speakers.
Steve
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #17 on: 25 May 2015, 12:13:23 »
Carl,
Steve
Correct, its a full active system, one Amp per Speaker (x 6), except the Tweeters which are just trimmed off the Front Mids via a crossover.
Bose do piss around with the EQ quiet a lot including Compression at different Volume levels, supposedly to match each individual Car Manufacturer acoustic interior.
They've been doing it for donkey years in the PA and Hi Fi world, claiming there's no point in producing a Flat Response Amp when there's no such thing as a Flat Response Speaker, so tweak the EQ of the Amp to match flaws in the speaker (generally a boost in lower and upper frequencies).
So yea, dont expect it to sound the same by introducing non Bose components.
deviator
  • Chesterfield
« Reply #18 on: 26 May 2015, 09:16:42 »
Sorry for jumping on anothers' thread, how do I know if mine is the Bose system?
It's a 2.6 CD, so I would probably think not.
:) Whilst I appreciate the comments, it doesn't actually answer the question. Sorry for being an 4r5e, but how can I tell if my car has the Bose system? Where will the amps be? Wiring perhaps?
I'd like to fit a more modern stereo, hence the question.
http://www.omegaowners.com/forum/index.php?topic=90490.0
Thanks  :y
