Author Topic: handbrake light flashes  (Read 2677 times)
omegatech
  • sheldon, birmingham
    • omega 2.2 cd petrol
« on: 22 May 2015, 19:55:11 »
Hi guys
I have noticed that my handbrake light on the dashboard flashes every so often even though the handbrake is lowered fully
Cheers guys
tidla
  • solihull
Re: handbrake light flashes
« Reply #1 on: 22 May 2015, 20:06:48 »
Have you checked the level of the brake fluid?
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #2 on: 22 May 2015, 23:07:46 »
Indeed, mine started flashing if I went uphill.
Doesn't mean a leak, just that the pads are wearing down and the fluid level is dropping as they wear.
4x4
« Reply #3 on: 23 May 2015, 06:39:19 »
If it is low,means you havnt been doing regular checks then,which seems to be a regular occurrence these days as everybody is meant to check the car is ok to use on the road,thats lights,tyres oil,coolant,screenwash,brake/clutch fluid,power steering fluid and tyre pressures .
chrisgixer
  • Woking ham
  • Banned
« Reply #4 on: 23 May 2015, 08:45:28 »
Water level included. ;)
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #5 on: 24 May 2015, 15:34:35 »
When mine did that it was a bad connection on the level sensor plug,
If it aint broken, you aint trying hard enough
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #6 on: 24 May 2015, 16:57:27 »
I didn't know this.  :-[ Its the same light on the dash for the hand brake on and the low fluid level warning when hand brake is off. Learn something new every day.  :y
« Last Edit: 24 May 2015, 17:00:07 by Andy A »
