Pages: 1 [2] 3  All   Go Down
Author Topic: SatNav CD Required or Not??  (Read 11879 times)
mka306
Re: SatNav CD Required or Not??
« Reply #15 on: 26 May 2015, 11:16:58 »
If your car is equipped with a GID, you only get pictorial images of upcoming junctions. If you have a CID, you can have pictorial or map images, plus pop-up close ups for complex junctions
How will I tell the difference, I've not received the car yet so I can't check but it would be interesting to know which I have?
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« Reply #16 on: 26 May 2015, 11:25:07 »
Mine is / will be a 2000 on a W plate f/l.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #17 on: 26 May 2015, 11:36:27 »
GID is Monochrome
CID is Colour
mka306
« Reply #18 on: 26 May 2015, 11:51:01 »
okay great stuff, thanks again for the help :y
  • Online Online
« Reply #19 on: 26 May 2015, 13:14:37 »
They problem with Sat Nav in Omega, is it needs the CD. As the lasers get tired with age, it struggles to read the disc.
In the morning with CD being cold, it will often spit it out, due to it being unreadable.
While it is accurate, I found it can spit the CD out mid route too.
Lack of full postcode can cause problems too, I've struggled to find some locations.
« Reply #20 on: 26 May 2015, 15:37:44 »
So change the laser, Mr Gadgethands :y
  • Online Online
« Reply #21 on: 26 May 2015, 19:07:45 »
Love too, but I don't I'd make it worse. Probably snap half the bits off  ;D
    • 530D M Sport, 330i Coupe
« Reply #22 on: 26 May 2015, 19:32:52 »
Fixed a couple that have done that by cleaning the lense properly, point being, if the unit can read the Nav disc say 80% of the time then to my mind it hasn't failed (You find a lot of these units have the original 2002 Nav disc in them, not a copy). If the unit can't read the disc at all under any circumstances then its time to replace it!
« Reply #23 on: 26 May 2015, 19:35:40 »
How are you cleaning it?
  • Online Online
« Reply #24 on: 26 May 2015, 20:13:08 »
+ on cleaning it, the NCDC in the 3.2 does appear to be unmolested. All original and working fairly well, so a little clean up would do well.
Be nice to use it on an up-coming blast to Darlington  :)
« Reply #25 on: 26 May 2015, 20:47:36 »
Getting in there by removing the Nav drive from the HU on the bench and cleaning the lens methodically with some cotton buds and pre-boiled water. If you look at the lens closely on a used unit you will see it has a film of dirt on it rather than just dust - much like the inside of a windscreen gets after a while.
« Reply #26 on: 26 May 2015, 21:09:42 »
Just boiling water, no other potions?
« Reply #27 on: 26 May 2015, 21:23:42 »
Boiled - let it go cold! - Boiled it just to remove any impurities in the water that would stain.
No potions as I didn't know the effect on the plastic lense.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #28 on: 26 May 2015, 22:13:33 »
Or just stop being completely ghey and use an iPhone/Samsung/Nokia and have a far better SatNav (including accelerometers, GPS, yadda yadda) full Postode Input, unlimited updates including POI's, completely customizable and another belter......... you can speak to people on it!  :D :D :D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #29 on: 26 May 2015, 22:17:51 »
Hmmm interesting might try this... Just a thought but what about deionized water?  :-\
Pages: 1 [2] 3  All   Go Up
Page created in 0.04 seconds with 20 queries.
