Author Topic: Which solvent?  (Read 1289 times)
Tony H
  • liverpool
  • Black Elites are luurvley
Which solvent?
« on: 07 July 2008, 17:46:55 »
Hello peeps, I have a problem. I'm trying to clean up a naviatin copmpass without much success. it's quite plastic bodied and quite old. the problem is about ten years ago to stabilise it in use I modified it using self adhesive foam rubber strip ( a bit like giant self adhesive draught excluder) now I need to remove the glue residue which is prooving difficult. Th solvents I have tried so far are meths, white spirit, petrol and  acetone, the latter  which actually started to attack the plastic  :o. Can any one advise what to use be it solvent or otherwise.
TIA Tony
Debs.
Re: Which solvent?
« Reply #1 on: 07 July 2008, 17:51:59 »
Plain`ol WD-40 works a treat!....soak well into the adhesive residue and it should come off cleanly when rubbed firmly.
« Last Edit: 07 July 2008, 17:52:52 by Debs. »
Re: Which solvent?
« Reply #2 on: 07 July 2008, 17:59:58 »
I read the header and immediately thought it was a question for Debs.  and bless her, you have your answer allready.  :y
Tony H
  • liverpool
Re: Which solvent?
« Reply #3 on: 07 July 2008, 18:10:29 »
I had a little bet with myself that Debs would come up with an answer.
Cheers Debs :y
Danny
  • Wigan, Greater Manchester
Re: Which solvent?
« Reply #4 on: 07 July 2008, 18:16:40 »
Cheers Debs :y
who won? ;D
Re: Which solvent?
« Reply #5 on: 07 July 2008, 18:20:12 »
Cheers Debs :y
who won? ;D
     ;D ;D ;D ;D ;D ;D
Tony H
  • liverpool
Re: Which solvent?
« Reply #6 on: 07 July 2008, 19:55:21 »
Cheers Debs :y
who won? ;D
Him of course the other half of my split personalty  [smiley=2vrolijk_08.gif]
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Which solvent?
« Reply #7 on: 07 July 2008, 20:03:30 »
what about vinegar?
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: Which solvent?
« Reply #8 on: 07 July 2008, 20:04:35 »
what about vinegar?
Exellent............ with chips  ;D ;D
Gaffers
Re: Which solvent?
« Reply #9 on: 07 July 2008, 20:10:46 »
what about vinegar?
lol
That'll be Furtnum and Mason's chips and vinegar for you for now on!  :y
Re: Which solvent?
« Reply #10 on: 07 July 2008, 23:41:10 »
Maplin sell cans of "sticky label remover" which might be worth a try if all else fails. Has worked for me.
