Author Topic: rear cigarette/power plug.  (Read 4689 times)
pauls
  • By the sea minehead
    • Bmw x3
« on: 27 May 2015, 20:03:15 »
How long does this stay on after key removed from ignition.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: rear cigarette/power plug.
« Reply #1 on: 27 May 2015, 21:22:27 »
Mine don't work unless key turned to first position at least,so always assumed they'd shut down as soon as key turned off.didn't give it a thought that there might be some kind of "delay" built in.Could be wrong of course!
    • 530D M Sport, 330i Coupe
« Reply #2 on: 27 May 2015, 21:29:38 »
Same length of time as the steering wheel radio controls stay illuminated if that helps. About 30 secs on both on mine at a guess.
pauls
    • Bmw x3
« Reply #3 on: 27 May 2015, 21:34:03 »
Thats great thanks. I have my sat nav plugged into it permanently and had a thought is it on all the time. If so will slowly drain battery.
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #4 on: 27 May 2015, 21:34:26 »
Does it work on the same circuit as the interior light, that goes off when you lock the car. If so, would have thought the circuit would be dead once the lock activates. Or as you say...with a delay if the car is not locked :)
« Reply #5 on: 27 May 2015, 21:43:32 »
I thought the consumer relay was 10 mins...  ...but don't quote me!
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #6 on: 27 May 2015, 22:27:33 »
It is - well about 5-10 mins - never timed it, and i'm not going to  :P
« Reply #7 on: 27 May 2015, 22:30:31 »
I think it largely depends on which model multi-timer module was fitted as it appears they vary by the different answers on here!  ;D
« Reply #8 on: 27 May 2015, 23:31:15 »
There's probably a fairly wide tolerance on them too. It's not a precision instrument. ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #9 on: 28 May 2015, 10:46:36 »
Only stays on, on Elites and some CDX's in my experience.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #10 on: 28 May 2015, 13:59:56 »
That's true for the whole car. Like a well padded hammer!
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #11 on: 29 May 2015, 19:05:27 »
I'll bid 15 minutes.
Hoof'land storeman.
pauls
    • Bmw x3
« Reply #12 on: 29 May 2015, 20:20:02 »
I unplugged it after 5 minutes, got bored watching and waiting for the little green light to go out.
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #13 on: 30 May 2015, 10:08:10 »
Same this way.  :y
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #14 on: 04 June 2015, 01:08:43 »
if you want a permanent supply lift the rear drivers side seat there's permanent 12v thereabouts.  think it may be for the heated seats, upstream of the rear heated seat timer.
