Fibre optic question
Started by The Sheriff, 29 May 2015, 12:05:54
Quote from: Monsieur Guffer on 30 May 2015, 11:07:48
Quote from: Marks DTM Calib on 29 May 2015, 13:35:49
Just beware Guffer, you can tap into fibre fairly easily, I would say easier to do unnoticed than cable......something we used to do occasionally in the lab. But of course the likes of Port Mirroring makes it dead easy no matter what the medium.
I know what you mean but I still feel it easier to MITM ethernet than fibre.  You need to be able to use the splice and weld gear as opposed to making two ethernet plug ends.  Plus the kit for fibre costs a fortune.
Obviously depends were you need to tap into the fibre.  Fibre sniffers/taps have the advanatage over Ethernet ones of being entirely passive, and thus difficult to detect.
Quote from: Monsieur Guffer on 30 May 2015, 11:16:45
There was a period when aluminium twisted pair was used for this which is f-ing criminal in my view as it is much less conductive and more prone to noise but was much cheaper than copper at the time.
yeah, around the early 70s.  Copper became harder to get, and prices rocketed, so the POT had to investigate other materials (not just due to price, but also the availability, and copper was save for areas that really needed copper).
Ali was deemed at the time to be a reasonable conductor.
The plan went tits up, as also at that time, wires were going underground, and were not ducted back then...  ...making it hard to replace when the error of their ways was discovered!
My parents telephone line is underground lead encapsulated!
Quote from: VXL V6 on 30 May 2015, 11:50:57
I recall when I used to do a real job 25yrs ago, some jumped up prick in a suit insisting there was no lead left in the ground, even when presented with a list of areas we all knew within 2 miles of the meeting.
steve6367
Quote from: Monsieur Guffer on 29 May 2015, 12:20:50
If you are taking about FO from your ISP then it depends on whether it is Fibre to the cabinet or to the house.  I have virgin FO to the house and I am relatively happy with it although I am looking at other options to see if they might have better reliability.
I have VPN, media servers and allsorts of external data flows and sometimes VM throughput makes these unusable.
Just be slightly pedantic, is VM not FTC with a coax link to the house.
No need to splice or fusion weld, just stripping the cladding and wrap a bare core around it....simple.
Gaffers
Quote from: Marks DTM Calib on 01 June 2015, 08:17:47
I would like to see that in practice, is it efficient?  get any packet drops?
http://en.wikipedia.org/wiki/Evanescent_wave
Packet loss will only be a function of SNR, so if you see some you add a few more turns, dead simple.
Gaffers
Everyday is a schoolday.  I had seen the FO sniffers which are a ballpark £500+ and thus out of reach of many but the most determined.  This is one I shall have to test, if the wife asks I'm blaming you ::)
Of course all this sniffing would be for nowt if/when encryption is used :y
Rods2
Interesting, thanks for the useful information. :y :y :y
Rods2
Quote from: TheBoy on 30 May 2015, 11:22:30
In high vibration environments I bet they also discovered that aluminium is also much more brittle.
