Author Topic: Improving fuel consuption?  (Read 3243 times)
Re: Improving fuel consuption?
« Reply #15 on: 07 July 2008, 23:27:02 »
.. and I bet your oven's on for more than 10 seconds a week. Mmmm.. Scones. :-*
« Reply #16 on: 07 July 2008, 23:37:34 »
This argument has been going on for years. As peeps have said in tech speak is right, hear it for yourself;
Start your car and let it tick over, listen to the engine note and look at the revs, now start switching on electrical items and you well hear and see the answer for yourself.
You get nowt for nowt. :y :y :y
« Reply #17 on: 07 July 2008, 23:38:43 »
Absolutely  :y :y :y
unclelicklug
  • Sheffield
« Reply #18 on: 07 July 2008, 23:40:03 »
If there's no load on the alternator then it will coast, the only losses will be parasitic - bearing friction, fan losses, belt loss etc as stated above.
Typical alternator output might be 60 to 100 amps, at 13.2 volts (typical system voltage) this is around 1000w - you'd need quite a few high load items running to demand this, say HRW, lights, heated seats etc. but that's certainly a feasible demand that might be put on the alternator.
So we're calling for about equivalent 1.3 horsepower electrical output from alternator.
Not much vs 115 hp output for a 2.0 litre engine?
But...there's some inefficiency so to produce 1.3 hp of electricity you need more like 2hp at the alternator shaft (ie from the engine).
Still not much?
Well unless you're driving everywhere at max throttle and power output you're probably typically asking the engine for say 60 hp or less (my 39 hp Hillman Imp would still clear 75 mph - when it wasn't overheating...).
So if you're using a lot of load on the alternator you could be looking at utilising 2/60 hp on electrical loads - say about 3% - that's a significant effect on your fuel consumption.
So on very rough and ready figures, in real life driving IMHO electrical loading can have a significant effect on engine load, ie fuel consumption.
« Reply #19 on: 07 July 2008, 23:43:38 »
Still not much?
I said that in a couple of lines. ;D ;D ;D
unclelicklug
  • Sheffield
« Reply #20 on: 08 July 2008, 11:14:20 »
Still not much?
But I explained it!!!
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #21 on: 08 July 2008, 12:45:48 »
Yup :y :)
« Reply #22 on: 08 July 2008, 12:50:07 »
Still not much?
I cannot see any circumstances when I would be running with a 1000 watt load for any length of time !!
Overall the electrical load is miniscule in comparison to the effects of your right foot !!  :)
« Reply #23 on: 08 July 2008, 14:22:55 »
For the miggy I know two working solutions (from experience) for low consumption..
A narrow exhaust channel and no demand for acceleration (grandma driving) ..  ;D
