When to change shocks
Started by Shackeng, 31 May 2015, 13:34:55
Quote from: tunnie on 29 June 2015, 20:53:48
Quote from: Shackeng on 29 June 2015, 20:15:41
Quote from: tunnie on 28 June 2015, 22:47:32
Can get a pair of Meyle shocks for less than a single B4, unless the quality is vastly different from their droplinks, I'll be going with them next.
Oh Gawd, GM, Meyle, or B4's :-\ :-\ :-\
Decisions decisions. ??? ??? ??? :y
If you get Meyle, be good to hear what they are like  :)
...you'll be a guinea pig. They may well be fine but buy at your own risk. B4's are, however, a known entity ;)
Quote from: Lazydocker on 29 June 2015, 21:37:00
True.  :y  But at half the price of B4s, worth a go. So even if they only last half as long, its not a problem. Easy job to replace, unlike V6 gaskets. (For unknown parts)
Plus Meyle are known good in other areas. So worth a punt in my book
Shackeng
Quote from: tunnie on 29 June 2015, 21:44:09
Plus a geo setup each time. :-\
Only for the fronts :y
Rear shocks last less time but should have no bearing on geometry unless you forget to unbolt them prior to levering them out ::)
I still hope its the rear drop links on mine, should get a little more out of the shocks.  Original GM shocks lasted 8 years, current GM ones been on 7.
Our of interest how much are GM ones?
Rear droplinks don't fail ;)
Couldn't be a more different design to the front ones if they tried... and they only get loaded in one plane, whereas the fronts also twist with the steering :y
chrisgixer
Quote from: tunnie on 29 June 2015, 23:27:37
Quote from: Harris K Telemacher on 29 June 2015, 23:17:38
They are original to the car  :-\
...and will see out a few more other cars life's as well. They are, as said, a completely different, and much more basic design. No ball joint, just a rubber eyelet with a bolt through it.
chrisgixer
Means little sadly. Meyle heavy duty rearward wishbone bushes barely lasted 18 months, compared to GM ones on 2.5 ish years and still going strong.
But they might be worth punt.
chrisgixer
...and wtf has gaskets got to do with the price of fish? :-\ ;D
Hmm. My shocks are original. 180k and 13 years old. Wonder if I should replace them? :-\
Shackeng
Quote from: tunnie on 29 June 2015, 23:16:02
Fronts £53.80 Ea +Vat
Rears £47.20 + Vat
On TC
Quote from: Shackeng on 30 June 2015, 10:15:41
Rears £47.20 + Vat
On TC
Thanks. Again double the price of Meyle!
Quote from: Kevin Wood on 30 June 2015, 09:46:48
Have you ever replaced the rear droplinks?
