Windows 10 Upgrade Notification Icon today.
Started by zirk, 01 June 2015, 13:14:42
tigers_gonads
Quote from: zirk on 03 June 2015, 12:14:40
Quote from: tigers_gonads on 03 June 2015, 06:31:05
I'm stuck using 7 Ultimate because my printer / scanner / ect won't run on Win 8  :(
Can I take it that it will be the same with this new supper dooper Windows 10  :-\
Win10, when its officially released (supposedly later this year, more like early 2016), should be similar to a mix of Win7 and 8 but with the missing Start Menu back again, so you should be able to run all the Windows Programs kicking around plus all the Win Apps from the MS Store.
Having said that Ive been running Win10 for a while now (Beta Test Version) and whilst its pretty good, its still very buggy, especially on existing Drivers etc, a long way to go yet, before its finished, but there under pressure to get it released in some form or another.  ::)
My printer and flat bed scanner was designed to work on XP / |Vista Chris.
Managed to find win 7 updates for both but lost some of the facilities with both the printer and scanner  :(
Also I tend to go kill lots of Serbians/ Yugoslavians and North Koreans on a flight simulator game which i've had for years but only just learning to use the aircraft cockpit in higher skill levels  :-[
Found lots of updates for the flight sim on the t'nternet but it has never run as smooth as when running XP / Vista.
Well Lightning's never had touch screen MFD's or even a radar which worked properly and the early Tornado's was very temperamental so sat in the back with the power on and having a play when the jockeys wasn't about was frowned on  ;D
It might probably be human interface error on my part then  :-[
The Sheriff
Quote from: mka306 on 04 June 2015, 07:39:42
Quote from: STMO on 03 June 2015, 21:14:34
Quote from: BazaJT on 03 June 2015, 21:04:55
So what happens if I don't click on the icon at all?I think at present my laptop is on windows7 home premium.
Nowt. Well.........I dare say they'll ask you again.......and again......
Pretty much exactly what happened when I clicked on it.....nowt??
When you click on the icon in the taskbar, it should bring up a window asking you to register your interest.
