What's your favourite tool?
Started by Webby the Bear, 01 June 2015, 21:34:20
Quote from: EMD on 01 June 2015, 21:57:13
Telescopic magnet thing  :)
They're even better with a light on the end!
chrisgixer
Should of known Kev. Should of known. ;) ;D
Although, I did forget my Plasma cutter. How, I don't really know. :-\
Quote from: chrisgixer on 01 June 2015, 22:50:39
Ahhh! The light sabre. ;D
EMD
Quote from: Nick W on 01 June 2015, 22:48:37
Ive been looking for a decent one but cant find any . Where did you get yours from ?
Omegatitis
chrisgixer
Quote from: Kevin Wood on 01 June 2015, 22:55:22
Yeeeeahs! Feel the force.... Of anything up to 8mm ;D
Quote from: EMD on 01 June 2015, 22:56:41
It was about £4 from a market stall.
Currently, my favourite tool is the bigger lathe I bought last year to replace a mini-lathe.
But the plasma cutter is a real time saver for big sheetmetal jobs combined with a decent MIG welder. There is also something particularly satisfying about doing a good aluminium weld, although I don't manage it very often.
biggriffin
Hoof'land storeman.
Quote from: biggriffin on 02 June 2015, 10:02:45
Hammer and mole grips.
Agreed.
This implement should not be used on genitalia.
omegod
Toss up between a little teeny blue flat screwdriver or my 10mm Halfords flexi ratchet spanner, i'm easily pleased obviously  !
deviator
We are all picking clever/expensive tools. I think we are overlooking the really useful tools...
Hammer
WD40 (Or better)
Cable ties
Gaffer tape
Gloves
If you need more tools in your box, then buy multiples of the above list.  :y
Mr Gav
Flexible magnet thingy, so useful for getting those dropped screws and bolts that you can't reach, not to mention fishing the grub screw I dropped down the timing chain case on my Senator  :-X
GastronomicKleptomaniac
Have I stumbled onto Mumsnet? The only acceptable answer is "hammer". Unless its "big hammer".
Quote from: GastronomicKleptomaniac on 02 June 2015, 16:46:14
You need to broaden your experience.
I'll see your "big hammer" and raise you a 12" petrol disc cutter.
I'm not surprised by Stemos comment, but I am surprised thatKevin didn't suggest his light bulb changer :-\
Rods2
A heavy duty CK flat bladed screwdriver with a hex area on the shaft so you can put some real leverage on those rusted screws that has taken in its stride many, many years of abuse and is none the worse for it. :) :) :) :) Abused for everything from a heavy duty lever to a small cold chisel. :o :o :o :o
When I was an apprentice if you won one of the annual Apprentice prizes, you got a voucher to spend at our local quality engineering tool shop. So the screwdriver didn't even cost me anything. :y :y :y :y
