Author Topic: Recommended Service oil for Y32SE  (Read 3637 times)
C20det
  • Belfast
    • 02 3.2 v6 Special
« on: 01 June 2015, 23:32:46 »
Just done an oil & oil filter on the omega yesterday (GM 10-40) and an OE Aproved oil filter
Along with Air filter & Cabin Filter
Also purchased some new NGK Laser Platinum plugs & fuel filter will hopefully get them in tomorrow night.
I want to service the gearbox oil & LSD oil can any you guys recommend what to use I don't mind the cost I just want to use the proper stuff to keep it right   :y (is there an additive for the diff oil? I had a look on autodata in work says that it takes 0.75L
Cheers
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: Recommended Service oil for Y32SE
« Reply #1 on: 02 June 2015, 00:09:44 »
http://www.omegaowners.com/forum/index.php?topic=130366.0
Dif oil is listed in the dif oil change guide.
Plugs won't make any odds. GM ones are fine. ;)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #2 on: 02 June 2015, 08:48:17 »
Cheers
I use GM 10W-40 semi synthetic in my 2.2i 2003, but when my son went to VX they told him he needed GM 5W-40 fully synthetic instead. He asked why and was told any of there engines from 2001 onwards now need to use the  GM 5W-40 fully synthetic.
Anyone know why or doesn't it really matter?
deviator
  • Chesterfield
« Reply #3 on: 02 June 2015, 08:52:24 »
VX do recommend 5w30 fully for cars after a date. However, these V6's have been about for many years and have been fine on 10w40, hence it's what I use. Older engines tend to get a bit leaky on the thinner stuff. If you are worried, change the oil more often.
« Reply #4 on: 02 June 2015, 09:04:35 »
Firstly they're clearly special... GM semi synth is indeed 10w40, but GM fully synth is 5w30 not 5w40 ::)
Secondly, the switch to fully synth was primarily made to appease fleet managers as it meant that VX could use 20k mile service intervals as a selling point... less frequent servicing allegedly reduces cost per mile in maintenance terms :-X
Either oil is perfectly acceptable for any Omega engine, and if you buy it on offer or using TC, then genuine VX oil is an absolute no brainer, even if you change it at 3-5k intervals... (it's about the same price per gallon as helfrods will sell you a litre for) :y
Andy A
  • Bristol UK
« Reply #5 on: 02 June 2015, 10:03:17 »
Just realized I put 40 and should have been 30.  :-[  :y
jb
  • bucks
    • 3.2 Elite
« Reply #6 on: 02 June 2015, 16:55:36 »
Don't recommend you use NON GM SPARK PLUGS.
Manual Gearbox oil is special gm oil although some say its just dex 3 atf.
The lsd rear diff need a tube of gm friction mod (£3.00 from gm dealer) added to the fresh oil or you can buy diff oil for lsd diffs from Fuchs and Silkoline etc.
jb
  • bucks
    • 3.2 Elite
« Reply #7 on: 02 June 2015, 16:58:15 »
LSD GEAR OIL FROM OPIE OILS SILKOLINE/FUCHS BOA 90 LS
« Reply #8 on: 03 June 2015, 19:40:02 »
Cheers
GM specify the fully synth after a certain date for fleet marketing reasons, to extend oil service interval to 20k.  Obviously you'd have to either not care about your car or be pretty retarded to leave oil in for anywhere near that long.  For petrols, it needs to be changed once its gone from clear to a darker brown. For diesel, 3k max.
driver115
  • caistor lincolnshire
    • 3.2MV6
« Reply #9 on: 03 June 2015, 22:31:09 »
GM 10w40 semi synthetic in both the 2.6CD and 3.2MV6 every 3k to 5k miles/twice yearly per vehicle, made a little easier with the screw on oil filter conversion, and yes used lubricants for 3.2 diff and manual gearbox from Opie oils :)
