Author Topic: What thread on oil sump plug?  (Read 1547 times)
artsoul_no1
  • sidcup, kent
    • Omega CD 2.6 v6 2002
« on: 02 June 2015, 10:01:46 »
Oil change yesterday (Thanks Amba  :y) and the oil sump plug was pretty chewed up so tried changing to an alternative plug but met some resistance going in. Tried original oil plug but again didn't screw in nice and smooth as expected.
On inspection of the sump thread it may be a bit rough as well so looking to recut the thread and get a new sump plug as a first option before shelling out on replacement sump.
Does anyone know the EXACT thread size so I can buy the thread cutter
Many thanks
Dave
amba
  • Medway towns
    • German V6
Re: What thread on oil sump plug?
« Reply #1 on: 02 June 2015, 10:03:54 »
Did a bit of research yesterday and think this is correct so hopefully a tap will redress the thread . :y
OIL DRAIN PLUG
LENGTH - 13.5mm
OUTER DIAMETER - 25mm
OUTER THREAD - M14 x 1,5
THREAD LENGTH - 10mm
FEMALE TORX
STEEL
ZINC COATED
the alarming man
  • medway kent
    • disco V8
« Reply #2 on: 02 June 2015, 11:56:00 »
I did have this problem with my first 2.2 sport....but yes after redressing the thread and new sump plug all was well...good luck :y
artsoul_no1
  • sidcup, kent
« Reply #3 on: 02 June 2015, 11:59:08 »
Thanks for the replies
deviator
  • Chesterfield
« Reply #4 on: 02 June 2015, 12:44:55 »
The sump plug is the same thread as the oil pressure switch. As I use a sump plug to stop drips/damage whilst lifting a v6.
