Author Topic: Mass Airflow Metre  (Read 1947 times)
Blue
  • Bournemouth
    • Omega
Mass Airflow Metre
« on: 03 June 2015, 17:19:55 »
Hi all, have a Vauxhall omega elite 1999 v6 automatic V reg. My airflow metre is playing up, when I go up hills it stutters, was plugged into analyser come up as a fault although the engine light did not come on but it had registered the fault, would there be any point in cleaning with a cleaning fluid especially for the job. Also if no go would you go down the route of a used one at about £35 or a new Vauxhall one at about £320,your thoughts please appreciated, thanks for your time!!
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Mass Airflow Metre
« Reply #1 on: 03 June 2015, 17:27:23 »
http://www.vauxhallworldparts.com/vauxhall.php?partnumber=90510156&partid=629
Presuming it's either a 2.5/3.0 V6
£200 here new, Used one should be fine though.
« Last Edit: 03 June 2015, 17:29:01 by Mr.OmegaMan »
Blue
  • Bournemouth
    • Omega
« Reply #2 on: 03 June 2015, 17:43:07 »
It's a 2.5 and thanks for your reply, appreciated!!
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 03 June 2015, 17:45:17 »
I don't see a problem in giving the MAF cleaner a go. if it doesn't work you would have to replace it anyway  :y
RIP Paul Lovejoy
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 03 June 2015, 18:05:30 »
PM sent, probably got one kicking around.
« Reply #5 on: 03 June 2015, 19:31:19 »
Sure its the MAF at fault? They either work or completely fail on 2.5/3.0 (unlike later engines). Reliable enough that 2nd hand is fine
Think it needs further diags before condemning it.
