Author Topic: Part number anyone?  (Read 2667 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Part number anyone?
« on: 05 June 2015, 05:54:40 »
Morning guys, does anyone have a part number for "o ring" between coolant transfer pipe and engine block (at the back of the "V"valley) please?
Miggy 's having a slight coolant loss from HBV as I could saw.
I'm going to replace cam covers again than replace HBV and while I'm there it would be good to replace that "o" ring just to exclude possible leak beside HBV.
Thanks in advance guys, Stan
Re: Part number anyone?
« Reply #1 on: 05 June 2015, 06:14:38 »
Standard dowty washers iirc... :-\
This any help... http://www.omegaowners.com/forum/index.php?topic=90588.0 ?
« Last Edit: 05 June 2015, 06:16:44 by Harris K Telemacher »
danzigfan
« Reply #2 on: 05 June 2015, 08:03:30 »
So if I buy a set of those one should fit?
« Reply #3 on: 05 June 2015, 09:55:08 »
Are you talking about the coolant bridge to each head (dowtys) or the main coolant transfer pipe to actual engine block (o ring)
PN for dowty:
13 12992647  68 18 084 -SEAL, RING
PN for o ring:
15 9128362  13 38 242 SEAL, RING, WATER INLET NECK TO CYLINDER HEAD
danzigfan
« Reply #4 on: 05 June 2015, 11:55:15 »
danzigfan
« Reply #5 on: 05 June 2015, 11:58:51 »
I hope it's not a violation of therms using other member's pic - if it is, freely remove and I apologize.
I'd like to replace a seal just as a precation  :-[
EMD
  • Noofhampton
    • 95t
« Reply #6 on: 05 June 2015, 12:35:14 »
Wow your going to town on that taking the engine out for a seal  :o :D Sure its a seal on the rear pipe . You can do a lot more work easier with the engine out  :D :y
Omegatitis
danzigfan
« Reply #7 on: 05 June 2015, 12:44:48 »
Oh EMD  ;D I drove 3.0 mfl yesterday for the first time and now I believe my 2.5 isn't really a candidate for taking engine out and replace every gasket on it ....it just isn't worth the effort....3.0 is much superior and tempting :P really.
So If I'm correct I should order following part as TB said right?
PN for o ring:
EMD
  • Noofhampton
    • 95t
« Reply #8 on: 05 June 2015, 12:56:36 »
Yes  :)
Should have listened to TB
Agree , and would like another or maybe a transplant  :-X
Omegatitis
danzigfan
« Reply #9 on: 05 June 2015, 13:12:44 »
Yep, puting a 3.0 lump into mine's 2.5 engine bay would be nice ::) and keeping 2.5 road tax and insurance...dirty minds I know  ;D
« Reply #10 on: 06 June 2015, 19:26:57 »
PN for o ring:
Correct.
Its just a large rubber o ring
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #11 on: 06 June 2015, 19:33:48 »
Water INLET neck.
Interesting, I always wondered which way the coolant flowed. :y
