Pages: 1 [2] 3  All   Go Down
Author Topic: Rocker cover gaskets  (Read 14746 times)
gbh
  • forest of dean
    • omega cdx 2.6
Re: Rocker cover gaskets
« Reply #15 on: 12 June 2015, 21:34:18 »
Thanks,who stocks this in the uk?
hoody
  • Scotland
« Reply #16 on: 13 June 2015, 19:45:18 »
If i remember correctly GSF sell them.
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #17 on: 14 June 2015, 21:31:36 »
Can't see them on there site,anybody else?
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #18 on: 17 June 2015, 14:29:05 »
Well i've found a stockist after sending an email to Germany and the response was very quick and professional so lets hope their gaskets are of the same standard..
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #19 on: 17 June 2015, 14:30:38 »
Thanks Bojan i'm going to give them a try!!
« Last Edit: 17 June 2015, 14:32:43 by gbh »
EMD
  • Noofhampton
    • 95t
« Reply #20 on: 17 June 2015, 15:23:44 »
Is that over here or Germany , i looked on the site but when i see the postage costs it wasnt worth it from Germany unless bulk ordering  :-\ Think you would be Guinea pig trialling them as no one else seems to have tested the longevity  :-\
Omegatitis
hoody
  • Scotland
« Reply #21 on: 17 June 2015, 17:39:18 »
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #22 on: 17 June 2015, 22:15:15 »
Well Vauxhall quoted £114 of course cheaper on TC if i could join,so had a quote today from Motorcare Motor Factors ltd of £8 each now that maybe for a pair not quite sure and i have to wait until July to get them but no rush.As i said i emailed Germany who quickly got someone in the UK to email me with local suppliers,their main distributor in the UK is Mahle,these gaskets were recommended by one of our members as above.Obviously the Vauxhall ones aren't that great otherwise we wouldn't have all these problems and we'll find out i'm sure
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #23 on: 19 June 2015, 10:18:52 »
The black sealant should i use Vauxhall as i read Loctite is the same or better?Loctite sl 5980 or 5900?Thanks
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
« Reply #24 on: 19 June 2015, 11:33:00 »
I used either Loctite 518 (the red stuff), or a sealant similar to loctite 5980.
Eitherway, you can use 5980, it withstands oil and tepms up to 250°C.
Vauxhall/GM stuff is probably made by Heinkel (Loctite).
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #25 on: 19 June 2015, 19:47:08 »
Thanks Bojan
gbh
  • forest of dean
    • omega cdx 2.6
« Reply #26 on: 23 August 2015, 22:30:15 »
Well I finally got the time and fitted the gaskets today,i've used Victor Reinz and so we'll see how they go.Thanks for the fabulous guide on here and all the help.
« Reply #27 on: 24 August 2015, 07:43:54 »
Keep us up to date. So far the pattern Cam cover gaskets have lasted anything from a few weeks to a few months, the exception being the ones that (I think) dbug is currently trialling.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #28 on: 24 August 2015, 08:25:38 »
I am curious why they are so prone to failure, and why buying the best is critical. As long as the breathers are clear they act only as an oil seal at no pressure, not a demanding role. Once the small breather is blocked they have to withstand crankcase pressure. Then you need the best gasket you can buy, and even that will fail eventually.
I reckon some garages (and some owners) fit new gaskets without clearing the breathers. They should fit GM gaskets! If the breathers are clear I reckon any gasket should do.
« Reply #29 on: 24 August 2015, 08:53:49 »
Very rarely do garages clean the breathers. They fail because they go hard and brittle. This seems to happen much more quickly on pattern gaskets.
Pages: 1 [2] 3  All   Go Up
