Author Topic: sticking/jumping rev counter  (Read 1495 times)
pauls
  • By the sea minehead
    • Bmw x3
« on: 06 June 2015, 11:24:03 »
Not sure how to explain this but here goes. Last few days I have noticed that the rev needle seems to jump from 0 to say 500 then climb smoothly, also it will do this when you brake and then thottle again. It does this more at slow speed than at higher speed. It does go away after about 20mins of driving. Any ideas please
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: sticking/jumping rev counter
« Reply #1 on: 06 June 2015, 14:03:07 »
I wonder.... If the clocks are starting to fail, as mine did. Although slightly different in that mine would "buzz" when not working, this got worse until rev counter failed completely with the speedo.
Or, crank sensor issue. No codes I take it?
pauls
    • Bmw x3
« Reply #2 on: 06 June 2015, 14:18:41 »
no codes, I have just checked battery and its sitting at 12.2v. i presume thats low
chrisgixer
  • Woking ham
  • Banned
« Reply #3 on: 06 June 2015, 14:19:44 »
If that's with a meter check it against Kevs charging guide.
« Reply #4 on: 06 June 2015, 14:28:01 »
..........and also check the earth straps for secureness
pauls
    • Bmw x3
« Reply #5 on: 06 June 2015, 17:10:56 »
Have read a couple of threads about earth straps understand if correctly there is 5 of them. I only know of 2. 1 under battery tray and 1 on the bottom of the sump passenger side. Can somebody give me the rest.
