Author Topic: Please Help!!!  (Read 14048 times)
Varche
  • middle of Andalucia
    • Golf Estate
Re: Please Help!!!
« Reply #15 on: 07 June 2015, 15:18:09 »
Good on yer James.  :y
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Please Help!!!
« Reply #16 on: 07 June 2015, 15:25:05 »
It does not matter who does the job as long as the OP is happy, and the Omega gets back on the road :y
mka306
Re: Please Help!!!
« Reply #17 on: 07 June 2015, 16:03:57 »
Totally agree, all I want is the miggy running how it should, luckily the car is off the road until I have completed all the necessary work and some not so necessary, but this is something that needs doing sharpish as I can't risk turning over the engine in it's present state. Now it will need a coolant flush, engine flush, oil and coolant change and of course the cooler unit, must say I didn't see that coming :o
Re: Please Help!!!
« Reply #18 on: 07 June 2015, 17:18:50 »
I've sent you a quote that I've no doubt seems free compared to using a dealer ;D
    • 530D M Sport, 330i Coupe
Re: Please Help!!!
« Reply #19 on: 07 June 2015, 17:25:49 »
I thought they modified the 3.2 cooler to prevent this happening?  :-\
Useless GM muppets  :(
They changed it to stainless steel, but that doesn't alter the fact that the coolant should be changed at regular intervals.
I'm not sure the chaps at Ellesmere Port (many of whom were laid off when 54degree V6 production ceased) would be particularly impressed with you calling them muppets.....
powerslinky
Re: Please Help!!!
« Reply #20 on: 07 June 2015, 17:34:23 »
The answer is probably gonna be "never"  . . . but . . . can you fit a used  stainless oil cooler if it looks in good condition ?  :-\
Just asking as the oil cooler was "supposidly" changed less than 2 years ago by the owner of my 3.2 breaker  :-\
I'm preparing for a barrage of flack on this question  . . . but just asking  ;D ;D ;D ;D
Re: Please Help!!!
« Reply #21 on: 07 June 2015, 17:45:02 »
Problem with a used one is that the threads often strip when you try to tighten the two big bolts down for a second time. You wouldn't, of course, lose anything by trying  :)
Re: Please Help!!!
« Reply #22 on: 07 June 2015, 18:05:52 »
Problem with a used one is that the threads often strip when you try to tighten the two big nuts down for a second time. You wouldn't, of course, lose anything by trying  :)
Edited because I am stupid.
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: Please Help!!!
« Reply #23 on: 07 June 2015, 18:15:38 »
Short runs also cause the mayo to accumulate in the header tank ;)
Could just need a coolant flush, then run it for a while and keep checking the header tank...
Not always a oil cooler failure that causes mayo in the header tank, could sometimes be one of the HG's is on its way out also.. or in my case - as I recently found out - both HG's had failed LOL
D.I.L.L.I.G.A.F...
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: Please Help!!!
« Reply #24 on: 07 June 2015, 18:19:32 »
Ooh. Mini needs a chat with master. ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Please Help!!!
« Reply #25 on: 07 June 2015, 18:27:03 »
Short runs will cause mayo to accumulate under the oil filler cap but never in the header tank. Only cause of mayo in the header tank is failed oil cooler.
I have changed 2 leaking coolers on late model V6,s so Im dubious about this alleged improvement on the later ones.
I have used a second hand cooler as a replacement, but as said, you need to take care with the thread on the cooler when installing it. Its not hard to cross thread the nuts and strip the threads on the cooler.
powerslinky
Re: Please Help!!!
« Reply #26 on: 07 June 2015, 18:28:49 »
Were not the  2.5's from your manufacturing year prone to HG failure though ?  HG failure is a rare occurance as far I am aware  :-\ :-\
 Looks like a def oil cooler failure from the OP's pics in my book
chrisgixer
  • Woking ham
  • Banned
Re: Please Help!!!
« Reply #27 on: 07 June 2015, 18:45:15 »
Masters comments here cover it I believe?
http://oldsite.omegaowners.com//forum/YaBB.pl?num=1263501823
chrisgixer
  • Woking ham
  • Banned
Re: Please Help!!!
« Reply #28 on: 07 June 2015, 18:48:57 »
I find that placing the nut over the threads loose, then fitting the banjo bolt in the cooler to pull the cooler up in place BEFORE screwing the nut onto the cooler, greatly helps the thread life. The cooler can sit a fraction low otherwise, giving a risk of not catching the thread correctly with the nut.
Apologies if teaching egg sucking, but better safe. :)
mka306
Re: Please Help!!!
« Reply #29 on: 07 June 2015, 18:56:07 »
I will buy a new one and get the coolant flushed out so hopefully all is well. If HG,s need doing then so be it but I'll start with the oil cooler and go from there.
Thanks to you all for the help it has made a big difference to how worried I was earlier today :y
Pages: 1 [2] 3 4  All   Go Up
