What sort of spec is needed for a media centre
Started by tigers_gonads, 09 June 2015, 16:16:11
omega2018
i don't think media center supports DAB either.  just to clarify though the digital radio i mentioned and which you can get through media center is not DAB, it is freeview. there are around 30 freeview radio channels. i vaguely recall the digital quality is better than dab but could be wrong, freeview quality seems to have dropped over the years.
tigers_gonads
Okay, I commandeered the dining room table this morning and started to build it up.
DVD drive fitted  :y
Processor fitted  :y
Whopping big heat sink which looks like a sub station fitted  :y
Hard drive fitted  :y
2 sticks of RAM fitted  :y
With a little bit of dismantling, the graphics card is now fitted abet in a slightly dodgy manor while the half height adaptor brackets arrive next week  ::) :-[.
And on to my next problem  ::)
At the end of the case, I have a Spectra Riser card fitted so that the full size TV / Satellite cards will fit in the case.
Looking on Ebuyer ect, these cards in PCI form are like rocking horse poo  :(
Now I know you can get adaptor cards to convert PCI into PCI e format  :y
The problem with these is that with the adaptor fitted, the chassis which holds the 2 TV card wont fit in the slot  :(
Does anybody know of a riser card which converts PCI into 2 x PCI e slots ??
Try to avoid the adapters, as they are universally shite, and always flakey.
Also, on that Spectra case, if you can avoid the riser card, as ultimately you will find that you will change the CPU/mobo, and most motherboards are a bit shitty with these type of risers.
Although not HD, the Hauppauge Nova 500DT gives 2 SD freeview tuners in a PCI card.  Downside is they are actually USB tuners, so standby is a bit naff with them. But I'd suggest a 2nd hand one could be had for under £20
tigers_gonads
Quote from: TheBoy on 26 June 2015, 22:34:47
Will look into it
Cheers TB  :)
tigers_gonads
Right, IT LIVES  :D :D :D
ish .....................
Managed to get Win 7 Ultimate installed okay  :y
Started Friday morning and it finally finished doing the update cycle this morning  ::)
Next problems  ::)
I cannot seem to get any output from the SPDIF coax, optical or RCA boards front and back  :(
The only sound I get is from the TV via the HDMI input.
I have tried setting up the sounds through Media Centre but to no avail  :(
I have checked the connections from the 2 boards too the motherboard and all imo seems okay  :-\
Also the front card reader is not working  :(
And also the case display / volume front control is not working  :(
The volume knob lights up blue.
The matrix display greets you on power up and shut down and also I have what I presume is the hard drive light flickering when the hard drive is active but nothing else  :(
Thinking this is driver related, i've checked the links off TB's link but some are no longer active  :(
Any ideas please .............
tigers_gonads
Okay, various drivers later, that lots working even though the card reader will not read SD HC cards  :(
Don't know if there is a software fix for this ??
Couple more problems for those that know how the hell Media Centre works  ::) ;D
I transferred 10 dvd's full of mp3 songs across to the music folder.
These are named All the number 1's 1953 - 2005 through to All the number 10's 1953 - 2005
Basically every tune that has been in the top 10 over the last 52 years  :y :y
I don't know what happened but Media Centre seen unable to catalogue these 10 albums as 10 albums  :(
If you enter media centre, they are catalogued in every which way but above and is a nightmare to use  :(
I was hoping to use a pair of rechargeable Wi-Fi speakers in the garden when funds allow so this is a real pain in the arse  >:(
Obviously you can use Media Player to play them in whatever order with no problem but as far as I can see, Media Player can't be configured to stream via Wi-Fi  :-\
DVD playback ................
I have set up the menus and have Dolby Digital output through the optical link to the AV amp.
Problem is that the output on media centre is set for night time by default which is seriously screwing up the sound on both films.
The menu is visible but locked out so nothing can be changed.
Mini Me had a play with the registry and changed the value so that it showed normal but the option was still blocked and I cant keep pishing around with the registry every time I want to switch between Dynamic, Normal and Night mode  :(
Anybody else got the same problem's and have a fix  ??
