Author Topic: Coolant Flush  (Read 5187 times)
mka306
Coolant Flush
« on: 10 June 2015, 19:03:23 »
Hi guys, is there a recommended coolant flush to use for cleaning out the cooling system after replacing the Oil Cooler, a lot of the stuff for sale states you must poor it into the radiator but I need to clean the expansion tank ect so would want something I can poor into there?
As always your superior knowledge is very much appreciated :y
Re: Coolant Flush
« Reply #1 on: 10 June 2015, 19:05:45 »
Firstly, do about 20+ flushes with water.
Remove bits you can, flush under tap.
Good luck!
mka306
Re: Coolant Flush
« Reply #2 on: 10 June 2015, 19:11:13 »
Do you need a coolant flush then or is it just water?
Re: Coolant Flush
« Reply #3 on: 10 June 2015, 20:02:12 »
I just run the hose with the engine running keeping a beady eye on the level.
Re: Coolant Flush
« Reply #4 on: 10 June 2015, 20:03:39 »
Oh, sorry...didn't read the piece about oil cooler failure.
I simply used washing powder.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Coolant Flush
« Reply #5 on: 10 June 2015, 20:56:18 »
Best stuff for flushing system after oil cooler failure is dishwasher tablets the liquid ones,or use dishwasher liquid. :)
Hoof'land storeman.
mka306
Re: Coolant Flush
« Reply #6 on: 10 June 2015, 21:04:35 »
Thanks for the advice guys, I'll get some dishwasher liquid and flush it out a good 30+ times no doubt and hopefully it will clean out the gunky oil in the pipes.
Re: Coolant Flush
« Reply #7 on: 10 June 2015, 21:09:42 »
Not dishwaher fluid, dishwasher tablets... Specifically the ones Aaron used as they work :y
Re: Coolant Flush
« Reply #8 on: 10 June 2015, 21:18:00 »
Screenwash worked quite well as well ::), but I'd flush the bulk out with water before moving on to chemical options, so the chemical options stand a chance of working.
biggriffin
Re: Coolant Flush
« Reply #9 on: 10 June 2015, 21:35:56 »
Couple bottles of distilled(white) vinegar properly be as good. :o
Hoof'land storeman.
Re: Coolant Flush
« Reply #10 on: 10 June 2015, 21:37:39 »
omegatoy used to suggest cap of bleach, with engine on idle up to temp. Helps break the oil down
mka306
Re: Coolant Flush
« Reply #11 on: 10 June 2015, 21:46:07 »
Don't no which one's Aron used but I will look for liquid tablets and go with that idea after a good few water flushes. :y
powerslinky
Re: Coolant Flush
« Reply #12 on: 10 June 2015, 21:57:12 »
Better to use dishwasher tablets. Put 2 or 3 in a small bucket with warm water & disolve them . Then add this to the header tank  filling the system as best you can ,  let it soak overnight , then flush out with hose . You will need to do this a lot of times .  Don't know about dishwasher liquid   . . . but I do know that dishwasher tablets work . HTH  :y
Re: Coolant Flush
« Reply #13 on: 10 June 2015, 22:02:52 »
I think we went through half a pack of .. I think they were Finish Powerball.
Fed a few into the header tank, ran till hot, span the cap off (dodge the volcano of sludgy water), drain, fill, repeat..
Re: Coolant Flush
« Reply #14 on: 10 June 2015, 22:11:28 »
That's the ticket... Still took twenty plus goes though ;D
Brutal but effective 8)
