Author Topic: Radiators  (Read 4917 times)
Andy89
  • Norway
    • 97 3.0 MV6
Radiators
« on: 10 June 2015, 21:50:12 »
Hi all
My radiator has started leaking in the plastic, so I need a new one
My car is a 97 3.0l with climate control, originally an automatic (but converted to manual)
Now that I need a new one, I want one that's for a manual and original gm
Does anyone know the GM number for one that's for a manual? (or does one only get 1 rad for all cars now)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: Radiators
« Reply #1 on: 10 June 2015, 22:58:14 »
Rads for Manual Gearbox car will not have the atf cooler part for the Automatic Transmission  :y !
Re: Radiators
« Reply #2 on: 11 June 2015, 07:36:40 »
Nor will a later GM auto one... ::)
They have a separate cooler ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Radiators
« Reply #3 on: 11 June 2015, 09:07:23 »
You will need the part number for a f/l model either a 3.2 or 2.6, as these had a separate gearbox cooler.
Hoof'land storeman.
The Omega Glory
  • Staffordshire
    • Elite Saloon
Re: Radiators
« Reply #4 on: 11 June 2015, 10:17:54 »
just replaced mine with a pattern NRF Rad. part no 00529689, on my 3.2L saloon. This has the the auto box cooler as part of the rad. They only make this type and is listed to fit both 3.0L and 3.2.
This should fit a manual because the integral auto box cooler is redundant on mine, having a seperate one.
The original has part no 52485466 on the back.
£80-£90 for the pattern, £ approx £240 for a GM genuine.
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #5 on: 11 June 2015, 15:18:56 »
When I ask Opel over here, they say they only got one radiator for omega 3.0l   (looks like "to me" that the auto/manual radiators are something old that aren't made anymore by looking at their computer)
Part number is 6302006  GM number is 52463050 (some code also said DF)
Does anyone know if this will fit and not have the auto cooling holes (witch I want to get rid of)
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #6 on: 11 June 2015, 15:27:59 »
This is the reason I want for a manual car  :y
So do all 3,2 and 2,6 radiators come without those holes?
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #7 on: 11 June 2015, 15:30:45 »
did a bit of searching, and if this is right the radiator has the auto holes
http://www.gmradiator.co.uk/index.php?page=search&stype=completes&sby=sbp&spartno=10665&comps_manu=&comps_model=Omega+-+B&comps_spec=2.5+i+-24V&comps_from=03%2F94&comps_to=09%2F99
gstylebaby
  • stockport
Re: Radiators
« Reply #8 on: 12 June 2015, 08:39:31 »
I have a radiator from my mv6 1999 manual estate that will be going on ebay not looked at properly to be honest but from what i remember from when i removed it its in good condition and was o.k on car no leaks.  Not sure on cost to send to you in Norway though.
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #9 on: 12 June 2015, 17:11:28 »
Thanks for the offer, but I'm after a brand new one  :)
biggriffin
Re: Radiators
« Reply #10 on: 12 June 2015, 20:22:29 »
2.6/3.2 is 52463050- is also listed for 2.5/3.0L with aircon
2.5 man exc air con to 95 is 52463046
2.5 auto exc air con 52463046
2.5/3.0L with air con 52463050.
2.2 auto to 00 52463046
2.2 auto from 01 52485464
Hoof'land storeman.
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #11 on: 12 June 2015, 21:28:04 »
So radiators without the auto bit is not available anymore?
biggriffin
Re: Radiators
« Reply #12 on: 13 June 2015, 07:39:35 »
You seem to be worrying for no reason.
Auto rad or manual rad the cooling area is still the same,just don't have the auto cooler in-built,but the blanks still there.
 just fit a 2.6/3.2 one :) :)
The keeper of photos Mr Rob G might have a photo.
Hoof'land storeman.
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #13 on: 13 June 2015, 13:51:58 »
I have now ordered the "52463050" witch is the one for a manual 2,6 and 3,2 (and for both manual and auto 3,0 it seems)
There was another number for the automatic for 2,6 and 3,2
Andy89
  • Norway
    • 97 3.0 MV6
Re: Radiators
« Reply #14 on: 18 June 2015, 15:02:28 »
This radiator had the auto connections, if anyone was wondering  :P
