Author Topic: Changing water pump without changing cam belt  (Read 4966 times)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Changing water pump without changing cam belt
« Reply #15 on: 13 June 2015, 13:41:01 »
Cheers TB.
I think the cling film, rags and brake cleaner followed by a dose of compressed air to dry will do the trick  :y
Cheers for the note about the pulley bolts  :y are you saying that they're too long, stick out the back of the part of the pump that spins and catch on the pump body?
That's exactly what happens. Then you have 2 options: 1 spend ages moaning about how that is utterly unacceptable and that the supplier should give you a brand new car as compensation; 2 - act like a mechanic and just deal with the problem by  using shorter bolts(they're M6 so that's easy)/cutting your existing ones down(the hard way)/adding a couple of washers under each bolthead.
As for the coolant leaking from the waterpump, you're over thinking things. Unbolt the pump, rinse the coolant off the pulley etc with tap water and fit the new pump. It's a Vx V6, so you're bound to have some cleaning up to do!
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #16 on: 13 June 2015, 13:46:22 »
Option 2 every time Nick  :y
Thanks for that  :y
RIP Paul Lovejoy
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #17 on: 13 June 2015, 19:00:54 »
Isnt there a pump with a plastic impeller that should be avoided?
« Reply #18 on: 13 June 2015, 20:09:30 »
Yup, catch on the strengthening webbing on the pump.
