Author Topic: rough rnning  (Read 8926 times)
flyer 0712
Re: rough rnning
« Reply #15 on: 14 June 2015, 22:08:39 »
I do not blo---y believe it  :o.......No time today to look at egr valve...so started the car and as recently it hunted,,stuttered,,on tick over...anyway drove it all was ok as usual, and popped in local petrol station to refuel...put £40 in and continued on my way..each time car slowed down it ran like a pig...I did around 20 miles in it before returning home..and then i noticed the tick over had returned  to normal,,,turned engine off and re-started it and it ticked over nicely,,,left it for two hours and then took it for a run to find that it appears to be ok now.(fingers crossed),,,then I remembered putting fuel in it around ten days ago at a Sainsburys petrol station and on visiting there half of the pumps were not available as the petrol tanker was in there refilling the tanks,,,so is it a coincidence that they had run so low on fuel that the petrol i purchased had water in it and now that has virtually used up and I have refilled with good stuff that it has worked its way through and will now be ok.......Would this have made my car run so badly on tick over and be harder to start or am I just hoping,,,regardless i will do the egr valve and give the old gal a good going over as the person who owned her before me certainly did not service/look after her at all... Thanks for all your good advice I have learned a lot from you all and hope i can pass this help onto others who are having problems with their migs, :y :) :)
flyer 0712
Re: rough rnning
« Reply #16 on: 15 June 2015, 21:07:25 »
the egr blanking plate arrived today and my question is.....do i use any gasket cement on both sides of the plate to make it air tight when i bolt it on between the valve and manifold...thanks  :y
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: rough rnning
« Reply #17 on: 15 June 2015, 21:35:46 »
Quick answer, No, but leave the original gasket in
Is it still running fine with the different fuel ?
Re: rough rnning
« Reply #18 on: 15 June 2015, 21:48:51 »
You know what, in nearly 10 years, 180k. I've never cleaned EGR, on my 2.2 :-[
Perhaps I should!
What benefits are there with blanking it off?
SIR Philbutt
    • PJB Home Services
Re: rough rnning
« Reply #19 on: 15 June 2015, 21:59:07 »
Perhaps I should!
So as to find out if, or exclude it from, possibly causing the problem.
AFAIK there is no benefit from it being permanently blanked (or even cleaned) on a 2.2, if anything I have read that fuel consumption will go up
Re: rough rnning
« Reply #20 on: 15 June 2015, 22:03:46 »
Thanks. I've never had cause to look at it, next time coil pack comes out, I'll take a look.
flyer 0712
Re: rough rnning
« Reply #21 on: 15 June 2015, 22:10:54 »
Yep after refilling with fuel all symptoms have gone and car now runs very well once again...convinced now it was water in the fuel....perhaps i will leave the valve as it is or at most clean it,,,,,it is only that the light is now on in the dash  ( the engine block looking light ) although does not affect the running of the car.....matter of asking,,would it fail the mot with that light illuminated on the dash..ta much
