Author Topic: v6 back breather box - large pipe  (Read 1678 times)
omega2018
    • MercCL500 Omega2.6ManElit
« on: 16 June 2015, 20:16:02 »
i have checked all the breather pipes except one - the large pipe on the back breather box.  i checked the small hole on it - it is fine. the black plastic breather bridge was fine with all ports clear.  the large pipe on the breather box seems a pig to get at without dismantling stuff, which is why i haven't done it.  given everything else was fine can i assume that one will be ok too?
EMD
  • Noofhampton
    • 95t
Re: v6 back breather box - large pipe
« Reply #1 on: 16 June 2015, 21:02:25 »
The Y piece breather can block , mine was blocked solid on the 2.6 from the previous owner  ::)
Omegatitis
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #2 on: 16 June 2015, 22:11:14 »
You can test it by pulling off the 2 outer pipes at the back of the plenum, blocking one and blowing into the other - if you can blow into it easily it ain't blocked.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #3 on: 16 June 2015, 22:12:49 »
What he said ^ :y
Page created in 0.008 seconds with 21 queries.
