Author Topic: F/L Door Strips  (Read 1950 times)
F/L Door Strips
« on: 19 June 2015, 21:12:18 »
The ones on the outside, how are they attached to the door?
I need to replace one.
Re: F/L Door Strips
« Reply #1 on: 19 June 2015, 22:22:32 »
Two torx screws, several clips and if you're really lucky, some double sided tape :y
Re: F/L Door Strips
« Reply #2 on: 19 June 2015, 22:57:33 »
Ta. Will investigate in daylight.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Re: F/L Door Strips
« Reply #3 on: 20 June 2015, 07:56:42 »
Had a whoopsy?
Quite an easy job on the face lift iirc?
Two bolts inside the door shuts as said, slide along (forwards?) and should come away.
TB swapped his doors so over he'll remember.
Re: F/L Door Strips
« Reply #4 on: 20 June 2015, 08:57:22 »
Searching suggests slide towards back, looking at older threads?
Not me, came back to it damaged  :(
omegod
  • liverpool
    • 2017 Seat Ateca
Re: F/L Door Strips
« Reply #5 on: 20 June 2015, 09:16:45 »
Two small torq screws and give them a tap towards the back of the car
chrisgixer
  • Woking ham
  • Banned
Re: F/L Door Strips
« Reply #6 on: 20 June 2015, 10:00:08 »
Backwards it is then. :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: F/L Door Strips
« Reply #7 on: 20 June 2015, 12:02:21 »
Yep
You can have that on the floor if you want Tunnie. Nobody will notice   ;D ;D ;D
