Pages: 1 [2] 3  All   Go Down
Author Topic: only 3 plugs left!!!!  (Read 12873 times)
Andy89
  • Norway
    • 97 3.0 MV6
Re: only 3 plugs left!!!!
« Reply #15 on: 21 June 2015, 10:32:03 »
There's one down by the lambdas that is reversing light, then there are 3 above that, that are for the two coolant sensors and the purge valve.
Then all the rest should just come out of the square plastic on top (on a manual gearbox loom)
« Last Edit: 21 June 2015, 10:34:06 by Andy89 »
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #16 on: 21 June 2015, 10:34:02 »
will go out and take a pic of the three plugs and post them up soon.  :y
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #17 on: 21 June 2015, 10:57:09 »
Think I may have sorted it. If someone can double check inlet manifold one above coil pack has 2 wires red/blue and brown/green. Other one hopefully is other inlet manifold valve on radiator brown/black and red/blue. Thanks Andy other is purge valve found the bugger in a drawer. Just a blue/red and brown/green to find a home for now
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #18 on: 21 June 2015, 11:06:03 »
Have found what looks like a temp sensor on one of the bagpipes is this one of my missing plugs?
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #19 on: 21 June 2015, 11:10:27 »
Multi ram? Square externally with a half moon cut out and a metal spring clip surrounding 3 sides?
If it's a plastic tang clip with 3/4 wires and an oval plug(iirc) might be maf. Although yours is a different maf to mine  so that might not be helpful.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #20 on: 21 June 2015, 11:28:34 »
One looks like a solenoid on the back of the radiator that looks like my brown/black and red blue
One looks like a air temp sensor above maf. With a blue/red and brown/green
Other was the purge valve.
Does someone know if I have the inlet manifolds the right way round? On Haynes there are two inlet manifold solenoids. But don't know which is which
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #21 on: 21 June 2015, 11:45:40 »
1 One looks like a solenoid on the back of the radiator that looks like my brown/black and red blue
2 One looks like a air temp sensor above maf. With a blue/red and brown/green
3 Other was the purge valve.
1: fits the colors of the solenoid on the back of the plenum
2: My inlet temp has those colors, what do you mean by that it looks like it?
one solenoid sits on the back of the plenum, and the other on the plastic inlet in front of engine.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #22 on: 21 June 2015, 12:14:49 »
on Haynes manual there is two solenoids for inlet manifold one with brown/black and red/blue wires. other with brown/green and red/blue but is this one the rear most?
when I took the loom off the engine I coded all the plugs with numbers and made a list on the computer. but I had my drive crash and had to replace it and lost all the lists I had so now I don't know what goes where. the plugs I have left are those three one defo is one of the inlet manifolds other FITS the sensor above MAF. and other red plug your found andy and was the purge valve
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #23 on: 21 June 2015, 12:40:49 »
You cant connect the front and rear solenoids the wrong way, unless you lengthen the wire for the rear solenoid (it won't reach the front solenoid.)
oh, that sucks  :-\
If you still wonder, then put up some pics of the plugs and where they hang round the engine
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #24 on: 21 June 2015, 12:52:06 »
i hae everything connected just those two pesky inlet manifold solenoids and im sorted now  :y
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #25 on: 22 June 2015, 18:58:46 »
What are you wondering about them?
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #26 on: 22 June 2015, 19:14:26 »
Wondering if I have the two inlets backwards or not :-[
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #27 on: 22 June 2015, 19:54:01 »
Inlets backwards how?
I don't think you can swap them, but I can check the color code on one of mine if that helps  :)
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #28 on: 22 June 2015, 20:01:31 »
If you could that would be great mate
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #29 on: 27 June 2015, 20:05:40 »
Brown/green and red/blue is the one at the rear of the inlet  :y
Sorry for the late answer
Pages: 1 [2] 3  All   Go Up
