Author Topic: Clutch engage point  (Read 2459 times)
wesagog
Clutch engage point
« on: 23 June 2015, 23:14:36 »
Hi,
I have Omega B 1996 with a hydraulic clutch system...
I changed the friction plate and the pressure plate but my car still start move just when the pedal near the top.
So, is the clutch pedal engage point adjustable or not? If yes, how to do that...
Thanks for help
Re: Clutch engage point
« Reply #1 on: 23 June 2015, 23:27:34 »
You can't  :y
Did you also change the release bearing? If not why not? :-\
wesagog
« Reply #2 on: 24 June 2015, 00:28:30 »
Yes I did, even it was good
wesagog
« Reply #3 on: 24 June 2015, 23:46:47 »
Your Help Pls.
« Reply #4 on: 25 June 2015, 00:03:09 »
Your Help Pls.
At risk of repeating myself...
The biting point isn't adjustable.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #5 on: 25 June 2015, 00:06:48 »
That's how they are I think. Never owned a manual personally, but the ones I have driven have a very long pedal and bite nearer the end of that travel.
Not something I personally think is good about the manual, hence prefer the comparatively much more refined auto.
All of which is of no use to anyone. Sorry.
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #6 on: 25 June 2015, 00:13:17 »
Agreed, my first omega was a manual and it had a high pedal. As long as it changes gear fine and doesn't slip then you are OK. I can't say they are all like that as I only had one manual omega, but I would suspect you are fine and just need to get used to the pedal travel.
Hopefully someone with more manual omega expertise will be along soon.
If it aint broken, you aint trying hard enough
« Reply #7 on: 25 June 2015, 01:19:52 »
Second post in fact :D
Should add that the previous two post were rather more eloquent ::)
