Author Topic: Rear offiside creaking - handbrake shoes??  (Read 3729 times)
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
« on: 24 June 2015, 12:52:45 »
So.....
Just put the car through an MOT 2 weeks ago and passed with flying colours - had just fitted new shocks and rear exhaust too. Have noticed that when first pulling away or going over bumps i get a creaking noise from the back drivers wheel area - so, had mechanic check the bushes - all fine, new shocks so not a problem but its still happening.
Hard to describe but its not like a clunk - more like if you had a very heavy door that creaked when opening. MOT didnt pick up any issues with bushes, wheel bearings are fine so im stumped. When its sat stationary and i push down on that corner i can hear it.
Someone had said that it could be the handbrake shoes worn and pressing against the internal drum - the handbrake passed the mot but has stuck before.
anyone else heard of this? Im selling her shortly but as im honest, dont want to pass on a problem!!  :D :D :D :D :D
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
Re: Rear offiside creaking - handbrake shoes??
« Reply #1 on: 24 June 2015, 13:09:50 »
It could be the handbrake shoes.
There is a spring withing the handbrake assembly (inside the rear disc), which can snap or slip out of position -> as a result, handbrake shoes don't have a 'load' which 'pulls them inwards' (removing it from drum surface). In this case, you can hear a variety of grinding noises from the rear.
Can it be heared often?
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
« Reply #2 on: 24 June 2015, 15:40:58 »
Hi Bojan- yes, usually when pulling away and turning corners slowly!! its just like an old wooden door creaking / something rattling in the boot - (although its deffo nothing in the boot  :D
« Reply #3 on: 24 June 2015, 16:10:11 »
What shocks did you fit? Elite should only have self levelling ones...
Also, were the top mounts renewed? If so, with what?
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
« Reply #4 on: 13 July 2015, 19:50:57 »
Hi- replaced them with Monroes - but.... I don't think the top mounts were replaced or would they come with the shocks? mine is a CDX 2.2
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
« Reply #5 on: 13 July 2015, 20:05:57 »
soz meant to say, it was the rear shocks that were done - not the front struts..
« Reply #6 on: 13 July 2015, 22:35:58 »
I take it someone else had fitted the shocks for you :-\
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #7 on: 13 July 2015, 23:55:12 »
How funny.....I was showing my cousin, a mechanic, my latest Omega on Sunday, and he lent on it and it squeaked. First thing he said was handbrake or rear brakes. Bounced it again and said the same...handbrake ;)
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
« Reply #8 on: 14 July 2015, 08:47:34 »
Hi - yeah my father in law! hes a mechanic but didnt notice anything wrong!! As you can tell, my technical knowledge is limited !lol and to make matters worse- my EML has now come on and the reader i have cant pick up a signal!!
Gonna get my handbrake shoes and springs replaced and start there  :D :D :D (for the creak- not the EML LOLOL)
SOPRANO999
  • KIRKCALDY
    • Omega 2.2 CDX
« Reply #9 on: 14 July 2015, 08:50:03 »
Thats exactly how mine sounds when you push down. As well as when u pull away. Gently applied handbrake at about 5 mph and sounded like a brick was in there so gonna get em changed  :y :y :y :y
then ill tackle the EML light thats just popped on  :'( :'( :'( :'(
