Author Topic: Help wanted Urgent  (Read 7586 times)
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Help wanted Urgent
« on: 27 June 2015, 12:30:42 »
i`ve removed the front wishbone bush (rear) but seems to be approximately 2mm smaller diameter than the GM ones I have got to replace them with  :-\
Is this right? I just can`t see the new bushes going in, I`ve tried to get them started with a press and a hammer and drift but it just doesn`t want to know.
Has anyone else come accross this with the aftermarket wishbones?
Re: Help wanted Urgent
« Reply #1 on: 27 June 2015, 16:34:21 »
Obviously aftermarket makers are free to make their bushes as they see fit. Certainly GM and the Lemforder ones I've seen are the same size though.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 27 June 2015, 16:37:34 »
How did you remove the old bush? Is the 'bone off the car? If you burnt or cut it out, you may have left some in place. :-\
If genuine GM, then they will fit in the correct place. :y
  • Auckland
    • Mazda MPV
« Reply #3 on: 27 June 2015, 16:50:11 »
What make are the wishbones? I wasn't aware of any variation in the size of bush used (even among after market wishbones).
I am with Shakeng, I think you still need to remove the steel outer sleeve of your old bushes.
Mr Gav
  • Leeds
« Reply #4 on: 27 June 2015, 18:46:14 »
The steel outer sleeve is removed along with the bush, it came out ok using a metal tube slightly smaller than the sleeve but I could tell straight away that it wasn`t going to go in. I bought two cheapy wishbones from Euro Crap Parts, as it`s due the MOT this week and I didn`t have time to mess about.
I`ll take some photos tomorrow  :y
« Reply #5 on: 27 June 2015, 19:01:12 »
Not had any issues rebushing Atp supplied wishbones either...
Unfortunately it sounds like you have just wasted your money :-\
Mr Gav
  • Leeds
« Reply #6 on: 27 June 2015, 20:30:38 »
In which way Al? Buying new wishbone or buying the bushes?
« Reply #7 on: 27 June 2015, 20:36:03 »
Both... As having pressed the bushes out, you cannot either fit or return the new wishbones to ECP for a refund :-\
  • Auckland
    • Mazda MPV
« Reply #8 on: 27 June 2015, 20:54:16 »
I think Mr Gav is saying that he has made an emergency purchase of a pair of wishbones to get him mobile again.
« Reply #9 on: 27 June 2015, 21:04:29 »
I read it as fitting new GM bushes to new cheapy wishbones :-\
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #10 on: 27 June 2015, 22:24:19 »
Indeed.
There's is noting to say a cheap o after market copy will be the same in any dimension as the part it's "copied" from.
This bush,link taken from google images  http://www.niparts.com/Fac/C8D8B0/MEYLE/6140350010.html
measures
614 035 0010
Height 46.                1.81102362 inches
Inner diameter 14    0.551181102 inches
Outer diameter 49.   1.92913386 inches
According to meyle web site catalogue
Mr Gav
  • Leeds
« Reply #11 on: 28 June 2015, 01:10:38 »
Correct Andy  :y
« Reply #12 on: 28 June 2015, 03:22:02 »
Ah ok... What make were the wishbones you are trying to refurbish?
Mr Gav
  • Leeds
« Reply #13 on: 28 June 2015, 10:21:55 »
No idea Al  ;D
I got them four years ago when money was tight, tbh they've lasted well, they've done about 30k and only the drivers dude bush has gone. I got them from an online Vauxhall parts place, don't even think I have the link anymore.
Shackeng
  • Ramsbury
« Reply #14 on: 28 June 2015, 10:40:50 »
It seems very strange that the pattern 'bones fitted the car OK, and yet new OE bushes wont fit them. ??? ??? ???
