Learning ECU query
Started by Webby the Bear, 29 June 2015, 20:45:46
Webby the Bear
Bang in TB cheers for explaining that.
It also means that if my car had a performance issue when flooring it (it doesn't, I'm just talking hypothetically) I could rule out miss daisy vs nutter scenario. . . Assuming it was serviced regularly, breathers clean, and it got the odd Italian tune up
RIP Paul Lovejoy
Just a thought - so don't shoot me
The ECU is programmed with a complex set of 3D maps. The maps should be just about perfect across the whole range of revs and load but due to Euro noise and emissions regulations the manufactures have (allegedly) tweaked selected areas of the maps to pass. (probably the areas where most power is produced)
Miss Daisy drives sedately, the ECU never strays into the tweaked areas of the map. The ECU learns nothing and the fuel trims don't change.
The next person who drives goes for an Italian tune up. The ECU uses the sub-optimal parts of the 3D maps, the ECU learns and changes the fuel trims to compensate. The engine now runs better in those parts of the maps :y
Just a thought...........
Phil L
Quote from: Marks DTM Calib on 30 June 2015, 08:40:26
Ok, some facts
1) The engine ECU does not learn your driving style
2) The engine ECU can not be reset by removing the battery
Right, now we have that straight lol, the ECU that does learn your driving style is the autobox......
Interesting, thanks
Wishing I'd not sold the 67 Mustang...
jimbo125
Complex and confusing at times, so fuel trims are the variable here then?
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
Quote from: Andy H on 30 June 2015, 20:44:34
Sadly not though as the map is not revised, only a long term and short term fuel trim on a per bank basis e.g. a single correction value for the full map.
Furthermore, on a standard engine running well, the fuel trims are pretty much zero.
So no, the driving style wont impact the map or engine running.  :y
Quote from: jimbo125 on 01 July 2015, 01:03:33
Yes and they are exactly as the name describes, a trim, e.g. a small correction value to ensure optimum fuel combustion and hence minimum emissions.
Consider how the engine management system works, in simple terms
1) A demand is applied by the right foot
2) The ECU weighs the air coming in (via the MAF - Mass Air Flow sensor)
3) The ECU looks at engine revs
4) The ECU considers the throttle position and, the rate of change of throttle position (d'throttle/dt)
5) The ECU looks up in the engine map the required mass of fuel required to properly combust the mass of air (so its like making a cake!)
6) The ECU injects the required mass of fuel (considering air temp for correction also, but this is a minimal change)
7) The ECU then looks at the O2 sensor to see how well it did.
Its at stage 7 that the correction values are created, and used to modify the mass of fuel injected.
Have a read in the guides section as I did a short write up many years ago on the cycling weak/rich of the mixture for optimal mixture control.
This is also why raising fuel rail pressure and various other mods don't work, as the trim value dials them out!
Diamond Black Geezer
Quote from: Webby the Bear on 29 June 2015, 20:45:46
So. I decided to do a little experiment.
For a couple of weeks I'd drive like miss daisy and drive real slow. After this period I'd take the car out and give it a thrashing and see how the power was delivered. After this time it definitely felt like it was a bit lethargic.
For the next couple of weeks I thrashed the car literally revving the nuts off it and flooring it everywhere  ;D I then after the same time did the same experiment and it certainly felt more responsive in the same conditions.
Now I like to rely on facts and evidence and 'feelings' are a bit untangle able so is this placebo or is this a real case of seeing the learning ECU in action?
My next question is if this learning ECU stuff is correct how does it learn the drivers style?
Placebo?
The Sheriff
Quote from: Marks DTM Calib on 01 July 2015, 08:51:39
Yep. Old school thinking for old school engines.
The Sheriff
Quote from: Doctor Opti on 01 July 2015, 11:27:45
Placebo?
No. It was his omega.
Quote from: STMO on 01 July 2015, 11:28:42
Placebo?
Hmm.....the new Vauxhall Placebo. That has a certain ring to it.
It's crap but everyone tells you it's a great car. After a while you begin to believe it. :)
The Sheriff
Quote from: Doctor Opti on 01 July 2015, 13:30:56
Placebo?
;D :y
 :D ;D :D
It's called the Ampera  :)
