Quad electro static speakers.
Started by chrisgixer, 30 June 2015, 19:02:45
chrisgixer
Well, kettle leads are no more. So need to source those.
Looking forward to firing these up. :)
Bigron
No old computers with spare leads, Chris? I think Poundland still do them, if not. Please report back on how you get on.
Promise me that you won't listen to the "reproduction", listen to the music - that is what Quads are all about.
Ron.
I have a feeling the Quads don't have standard IEC mains cables. Trying to remember. :-\
Oh, and I still have the 546, hgave managed to keep it in working order and still fire it up every so often. Not usually at this time of year, mind. My study in the loft gets quite hot enough without all those valves - 500 watts worth! Due to the mammouth tube it has a much brighter, clearer trace than any other analogue scope I have access to, and the large front panel means the controls are easier to locate IMHO.
Bigron
Kevin, stop making me feel old! In my early engineering days, those 'scopes were the first ones I had ever come across with dual timebases and they fascinated me, as a teenager, the way I could use the "A delayed by B" function to examine a small part of a complex waveform.
Nowadays such features are commonplace, of course, and with much less heat!
I have no idea how much it cost, but annual maintenance by Livingstone Laboratories (do you know them) used to take the 'scope, clean it in an ultrasonic bath, replace all of the valves, regardless, and calibrate it fully. The plug-in Y-Amplifiers were terrific, too - such high quality construction.
I do apologise to members for this piece of self-indulgent nostalgia.....
Ron.
D
Didnt they use bulgin plugs. I think the latter ones had IEC conectors? Or perhaps the IEC was a owner retrofit? A lot of these are modified by previous owners.
Quote from: D on 04 July 2015, 11:07:36
I think you might be right. :y
Rods2
chrisgixer
Thanks Rods. But normal kettle plug type leads.
chrisgixer
Quote from: chrisgixer on 07 July 2015, 22:02:18
Presumably a newer pair.
Or someone has modified them. Good news, because they are much easier to get hold of. Got a stack of them hanging up here... ::)
chrisgixer
Found one.
Do they take one lead each or are they wired in series...?
One lead each into a mains socket.
They can take a while to charge the panels fully after powering up, so turn them on then grab a cuppa before starting to listen to them.
If they've been stored in cold or damp conditions, give them a day in the house before powering them too.
chrisgixer
Ooh. So I could fire one up? Banana jacks. Craplins? Just over the road from work.
chrisgixer
There's a plug setting on the back in the pic. Presume that's correct at 240 volts?
