Author Topic: Fuel pump question  (Read 2302 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Fuel pump question
« on: 05 July 2015, 17:44:33 »
What is it in the omega's fuel system that maintains fuel pressure after you've switched the car off?
I'm aware that some have a one-way ''check'' valve in but I think someone mentioned a while ago that the omega pump doesn't have one...so what does it have to maintain fuel pressure?
RIP Paul Lovejoy
Webby the Bear
  • Northampton
Re: Fuel pump question
« Reply #1 on: 06 July 2015, 17:23:21 »
anyone? lol
RIP Paul Lovejoy
« Reply #2 on: 07 July 2015, 07:32:41 »
The pump... ::)
Oh and the fuel pressure regulator ;)
Webby the Bear
  • Northampton
« Reply #3 on: 07 July 2015, 17:55:29 »
Thanks taxi.
what is it in the fuel pump that achieves that? I.e. A check valve?
And how does it achieve this with the fpr as I thought that just controlled pressure during running?
RIP Paul Lovejoy
« Reply #4 on: 08 July 2015, 16:05:56 »
Thanks taxi.
Why overcomplicte things... pump on and fuel flows, pump off and it doesn't... ::) typically runs at 5-6 bar.
The FPR knocks it down to a consistent, useable level where it is needed, ie at the fuel rail ;)
« Reply #5 on: 08 July 2015, 16:50:29 »
But that does not explain why fuel pressure remains after turn off  :y
To answer your question Webby, most fuel pumps have a one way check valve after the pump motor.  :y
Webby the Bear
  • Northampton
« Reply #6 on: 08 July 2015, 17:41:55 »
Exactly  ::) (I'm copying Taxi with rolling eyes there  :P ;D)
Thanks Mark, much appreciated  :y
RIP Paul Lovejoy
